Team Associated RC8Be Thread >
Old 02-20-2011 | 06:13 PM
  #3076
GreggW's Avatar
Originally Posted by jwmustang
Slash, I agree with Gregg. It only makes the noise sometimes. They all do it. If you go way back in this fourm you will see others talking about it and there is a full explaination about it. Something about the design causes it. I cant remember exactly.
To me it sounds the same as mine. I can't tell the difference between yours and mine.
GreggW is offline
Old 02-20-2011 | 06:30 PM
  #3077
smkmoto's Avatar
Question guys....
My buggy may have 2 hrs total run time on it, and it appears that on the front diff housing where the bearing from the driveshaft sits, is wore out! There's a lot of play between the housing and the bearing! Is this a problem area on these? It just seems like it's a little too early for the bearing housing to fail !
The rear also has a little play, but nothing like the front.
smkmoto is offline
Old 02-20-2011 | 06:38 PM
  #3078
GreggW's Avatar
Originally Posted by smkmoto
Question guys....
A picture is worth 1,000 words. I know where you are talking about. But how much play are we talking about? If it is worn out, replace it with a Boca or Avid. So post some pictures so we can get this figured out. I'll check mine now to see if I have some play in mine.
GreggW is offline
Old 02-20-2011 | 06:41 PM
  #3079
smkmoto's Avatar
I'll get a pic in a few. I'm assuming that a Boca and avid is a bearing?
smkmoto is offline
Old 02-20-2011 | 06:44 PM
  #3080
GreggW's Avatar
Yes, both are higher quality bearings.
GreggW is offline
Old 02-20-2011 | 07:00 PM
  #3081
schnellschnell's Avatar
I HAD THAT KIT! I loved it so much. Long gone though, don't recall what happened to it.
That is amazing that you will be getting yours running again. Post some pics of it for me, and a running vid would be great. Let me know if you ever want to sell it, total memories!
j
Originally Posted by Doug2507
Since my RX8 is away back to the states for repair i'm without car for now. Well thats what i thought till my folks just phoned and told me they found my old car up in the loft.....
+ YouTube Video
I'll pick it up on Monday. Super excited as i thought i'd given it away years ago. Still got everything thing to go with it from the sound of things, even the optional slick tyres!! Just hope the electronics are still working!
schnellschnell is offline
Old 02-20-2011 | 07:01 PM
  #3082
GreggW's Avatar
I just looked at mine. It moves a little. But it doesn't sound like what you're talking about.
GreggW is offline
Old 02-20-2011 | 07:25 PM
  #3083
Anyone have the FT rear hub carriers? Mine have small holes perpendicular to the Outer Hinge Pins. The holes are threaded as if for a grub screw. These holes are NOT on the plastic stock ones. Can't imagine wanting to attach it to the hinge pin. But what are the for, and are they supposed to be on the forward or rearward side of the car? The carriers are otherwise identical.
Carrier is upside down in the pic to better show the holes.
j
Old 02-20-2011 | 07:29 PM
  #3084
GreggW's Avatar
j
Those are for grub screws. To keep hinge pins from migrating.
GreggW is offline
Old 02-20-2011 | 07:33 PM
  #3085
GreggW's Avatar
j
That Porsche is awesome!! Classic!
GreggW is offline
Old 02-20-2011 | 07:56 PM
  #3086
jmackani's Avatar
Originally Posted by Tyler350
I agree 117. I plan on switching over to the RX8 once they get all of the issues reliability wise sorted out.
The issues are worked out with the tekins. We have 4 of them and not a single problem. Randy or Ty will probably easily speak to this. Also, Gregg, it's quicker to just call and get the RA number or use the live chat instant support during normal business hours on their website. I hate to say it, but I am pretty confident now that any problems with tekins are user error in programming the speed control.
jmackani is offline
Old 02-20-2011 | 08:02 PM
  #3087
jmackani's Avatar
Originally Posted by GreggW
Just from watching the guys at the track yesterday trying to run 2 classes at the same time. Race 1/8th, turn marshall the next race, Race 1/10th turn marshall the next race. They didn't even have time to work on things broken, and sometimes had to drop out of the next race because they were running back to back. Im too lazy for that. I don't mine turn marshaling at all. But they were pretty busy. Dont think Im going to do it. And I have 4 cars now.
There is a simple fix for that. It's called throttle control and then you don't worry about the breaking part.
jmackani is offline
Old 02-20-2011 | 08:03 PM
  #3088
GreggW's Avatar
I understand the user error thing. I'd just like to know how I could have messed it up using the hot-wire, running stock settings. Im having trouble even getting the lights to stay on after I do a software update.
GreggW is offline
Old 02-20-2011 | 08:04 PM
  #3089
smkmoto's Avatar
Hard to tell here, but you can see the gap around the outer race of the bearing. It has quite a bit of play. Here's the pics:
smkmoto is offline
Old 02-20-2011 | 08:10 PM
  #3090
GreggW's Avatar
Can't avoid people crashing into you. Which is what both broken parts I witnessed yesterday.
Hard to tell here, but you can see the gap around the outer race of the bearing. It has quite a bit of play. Here's the pics.
Mine has a little bit of play. But there isn't any way of telling hoe much you have without seeing it in person. Or a video.
GreggW is offline
