Team Associated RC8Be Thread
#1696
[QUOTE=GreggW;8567926]The track is in Antioch, and it's indoors. Well they call it indoors, it's outdoors covered.
[QUOTE]
oh haha so its one of those tracks. looks pretty fun. hopfully ill get a chance to go out and race it sometime this year. but the grid motor mount looking pretty sexy
[QUOTE]
#1697
No I definitely could have run. But it was just a slow day. Only about 20 racers. Was boring. Last weekend there were 86 entries. And a few local pros. It was all Nitro Buggy and Truggy. On electric weekend it's 1/10 buggy, SC and 1/8th. As soon as I got there, I was ready to go home.
But I'm glad I did. I just checked the mail and got a new toy
#1700
Ok, thanks for clearing this up. But that don't keep me from making this little collar in my lathe so i can put it on the motoraxle and have it supported in the bearing, or maybe even machine down the shank on my gear if it has a too large diameter
Well, that is if i end up with this mount sooner or later
#1701
The mount looks really at home in your RC8Be Gregg!
As for the confusion on the mounting holes for the motor plate. The Neu/Castle motors are like all other motors with M3 holes at 25mm mounting centers spaced 90 deg circular pattern, which is four holes for the motor.
The Tekin is slightly different where the mounting holes are at a 25mm mounting centers but spaced 60 deg circular pattern allowing for 6 holes. The Tekin has four of the six holes M3 and two with M4.
So essentially, any motor can be used.
The ball bearing is a M5x13mm. 1/8 motor for cars application have 5mm shafts. If you decide to put a special motor in with either a 4mm or 6mm shaft, just change out the bearing to a M4x13mm or M6x 13mm.
If you don't like the ball bearing, you can also take it out.
The other thing we highly recommend is to use more than two mounting screws if you are going to racing on a bumpy and jumpy track. With three or more screws, you have added insurance if one comes loose.
#1702
j
#1703
I thought I had read somewhere that they only fit the castle or Tekin. But there you have it, straight from Grid. I have 2 screws installed and
Loc tited in. I need to pick up a few more. I would also recommend getting an aluminum forward bulkhead because my top forward screws don't get all that tight. That will be my next purchase along with the new hubs. And schnell, I can't imagine the factory team ones are all that much better than the new Integy ones. They are both billet and this one is hard anodized. So we will see. These look good too. I'm in though. I'll order some in a few days.
#1704
#1706
#1707
#1709
Also we use plastic rear carriers because they are cheap to replace and hold up well. The other thing to consider is to keep the unsprung weight down. As you go further out from the suspension arms, try using light parts to boost suspension performance. If the wheel/tires could weigh nothing, buggies would drive on rails.
#1710
Your problem with the front plastic bulkhead is normal. We use only the plastic ones because they are very light. Just get a new plastic front bulkhead and replace those front metric screws with 4-40 x 1" socket caps. The stock metric ones have fine threads which chews up the plastic quickly. The 4-40 is imperial and coarse and do not. Keep the rear ones metric.
Thats a good idea. I never thought of getting different pitch screws. Thatd a good idea! And I have a spare set of plastic rears because I watched my friend break a set first time out. I broke my right rear upper turnbuckle luckily the hobby shop at the track had a few bags.
