Team Associated RC8Be Thread >
Old 01-10-2011 | 04:29 PM
  #1021
117's Avatar
117
Originally Posted by jmackani
I sanded mine and it did not fix it. I tried sanding twice to ensure it was flat. Simple fix for me was some silicone rtv on both sides of the gasket. No leaks now.
Try the Mugen gaskets. That might do the trick.
117 is offline
Old 01-10-2011 | 04:38 PM
  #1022
jmackani's Avatar
Originally Posted by 117
First off, I have to say woohoo!! This car is a hoot to drive. Much, MUCH more fun than my RC10B4. The RC8Be is so much more stable at speed and it can really put down the power! I was able to run full blast down my street without too much drama, and I was able to stay fully in control. Brakes were too aggressive and locking up, but that's just an adjustment issue. Tires were ballooning like crazy, so the next set for the street will need to be taped, belted, or foams. It was waaaaaaaaay too fast for being any use on a track or in the dirt. Setup is 6S Zippy 40C battery, MMM w/1800kV Neu motor, 21T pinion, stock 46T spur, ProLine Road Rage tires on ProLine V2 wheels. The tires were out of balance as well, and I could tell at high speeds.
Doug, I'm glad I can help now since these guys have helped me quite a bit.
I would HIGHLY recommend the EFlite EC5 connectors. 5mm barrel connectors that are easy to solder, easy to connect/disconnect, and they seem to handle the power, no problem. The connectors were not any hotter than the wires after this last run I had.
Not sure if 60C is going to be worth the additional cost over 40C. My car had TONS of punch and seemed to get up to full speed very quickly. For this car, I'd use as large wire as you can. At least 10 gauge (IIRC, the batteries I bought are wired with 10 ga). Heck, I'd use 8 ga if it would fit! I also like a single battery to make the wiring more tidy.
As for pinions, I used what Grid recommended, and they seem to work very well. I ended up buying Hot Racing 1M 17T, 19T, and 21T pinions. Definitely not cheap, but they are very compact, appear to be well made, and I didn't have any problems with the set screw backing off during this run.
I didn't use the Kyosho gasket (although I think you might be thinking of the Kyosho red o-rings, which were recommended until AE updated their o-rings to the clear ones). I highly recommend the Mugen gaskets. They're made with real gasket material vs. the AE paper gaskets.
Now, on to my questions.
Given the setup above, after a bunch of full throttle blasts down the street, and a bunch of heavy throttle accelerations here and there, I brought the car in. Ambient temp was around 35F. Here are the temps:
Motor - 150F on the case, 162F on the end bell
ESC - 118F at the bullet connectors, 110F around the battery side
Batt - 110F around the shrink, 115F at the exposed end
Wires/connector - didn't feel hot at all, maybe warm, but my hands were cold from being outside! I did not measure with the temp gun.
These seem a bit high to me since the ambient temp was so low. No vents or anything in the body, and there wasn't much intermediate driving (i.e. lots of blasts, then very slow driving, so not much air flow after the full throttle passes). I didn't notice the fan on the ESC at all, but the Savox servo is pretty loud, even at idle. What do you guys think?
It was insanely fast, but I'm thinking about buying a couple more sets of 6S batteries. For the track, I can see how 4S would be PLENTY.
Also, the MMM seems to stutter a bit in certain situations. For instance, if the car is coasting backward, and I give it some throttle, it'll stop the car from coasting back, stutter a bit, then start going forward. The stuttering seems to happen mostly with any change in direction, or right after putting on the brakes to a complete stop, then attempting to move forward slowly. This is a bit surprising to me as the MMP in the RC10B4 never seemed to exhibit this behavior. I don't think it's the battery, and I tend to think that it's the fact that it's not sensored. What do you guys think?
EDIT: I just hooked up the battery to the car on the bench, and gave it a go. Even with very, very little throttle, the motor and everything turns flawlessly. No stuttering at all. Tried going backward then immediately forward, worked perfectly. Sometimes a tad bit of hesitation during the back/forward transition, but no stuttering. Now I'm confused...
Running sensorless will cause the stuttering/cogging that you are experiencing. I would also recommend putting some holes in the body. I race normally and we almost always have to put holes in the body to get air into the esc and motors.
jmackani is offline
Old 01-10-2011 | 04:51 PM
  #1023
Soooooooo I'm wondering if I should sell my b4 ARR (just need tx and rx) for 300 ish then get a roller 8be or spend some birthday and get a used one from someone? I REALLY want a 1/8 scale but I'm gonna miss the b4. Is 1/8 really a lot more fun then the 1/10 and more durible? I'm kinda hesitant about doing this..
SLO county race is offline
Old 01-10-2011 | 05:08 PM
  #1024
117's Avatar
117
Ok, that's what I was thinking. I wonder why I never seemed to notice this with my B4. Anyway, I'm going to drive it more and if it ever gets annoying, I'll probably shop for a Tekin RX8.
Everything is cheaper for tenth scale, that's for sure, but so far I'm loving eighth scale.
117 is offline
Old 01-10-2011 | 05:28 PM
  #1025
jmackani's Avatar
Durability is quite different. Although, if you don't wreck, then you usually do not have to worry about that. Not cheaper though. A tekin system will cost you about what you are looking to get sell your b4 for. Till, you get batteries, decent 4s capable charger, speedo, motor, tires, etc. I would say 800 minimum.
jmackani is offline
Old 01-10-2011 | 05:36 PM
  #1026
jasons36's Avatar
anyone have a part # on these Mugen diff gaskets?
jasons36 is offline
Old 01-10-2011 | 05:39 PM
  #1027
117's Avatar
117
C0257
117 is offline
Old 01-10-2011 | 05:46 PM
  #1028
jasons36's Avatar
C0257
thank you sir!!
jasons36 is offline
Old 01-10-2011 | 05:51 PM
  #1029
I already have a charger and was looking at a 4s for like 40 from hobby king.
Old 01-10-2011 | 09:15 PM
  #1030
GreggW's Avatar
Billy, I think you're used to running the smaller set ups. In my opinion, that's what's happening here. I have a 2200 and you wanna talk about fogging! I can barely push the car with it off. It's crazy tight!
GreggW is offline
Old 01-10-2011 | 09:40 PM
  #1031
GreggW's Avatar
Receiver standing up.
GreggW is offline
Old 01-11-2011 | 12:45 AM
  #1032
JamesArluck's Avatar
Has anyone had problems with breaking the plastic ball ends for the steering links? I've broken 2 so far and am looking for a stronger alternative.
JamesArluck is offline
Old 01-11-2011 | 04:05 AM
  #1033
117's Avatar
117
Thanks for the picture Gregg. I ended up mounting mine on the opposite side, but it fits fine. I didn't use my super thick servo tape because it was too thick, so I ended up using the stuff included in the kit.
In the process, I found out I did something stupid. I usually super glue the antenna cap on the antenna tube, but this time I did it when the wire was in the tube. Yeah, I know...and yes the antenna wire is stuck, and it's stuck good. I don't know what I'm going to do at this point, other than leave it the way it is!
So does a sensored setup like the RX8 with say a 1900kV motor completely eliminate this stuttering/cogging, or is it still present, but much less severe?
117 is offline
Old 01-11-2011 | 05:06 AM
  #1034
jmackani's Avatar
Correct a sensored setup does eliminate this. As long as you sensor wire is good.
jmackani is offline
Old 01-11-2011 | 05:12 AM
  #1035
117's Avatar
117
Do the sensors and/or sensor wires fail often?
117 is offline
