Hobbywing Justock esc >
Like Tree4Likes
Old 12-22-2020 | 02:39 AM
  #241
I bought mine relatively recently and the brakes on 100% were strong enough to lock up the wheels on asphalt (track's closed so I can't test on carpet yet). On 75% they're a little weak though, so if you want to set you brake in the ESC, get a different one, if you don't mind setting it in the transmitter via DR this one works fine.
kawasaki161 is offline
Old 01-01-2021 | 02:09 PM
  #242
Any firmware update on yours Kawasaki?
purplegrape is offline
Old 01-01-2021 | 04:10 PM
  #243
Nope, no idea which fw it's running. I was too cheap to pick up a program card, there's so few settings I didn't see the point. I'll probably pick one up with the next time I need to fill some buffer for free shipping.
Old 01-06-2021 | 05:54 AM
  #244
i picked one of these up to toss in a 17.5 2wd car and was wondering if its possible to eliminate the switch?
didnt think of that when i bought it as i hate external switches. i may end up selling and just buying a xr10 stock spec
ray4624 is offline
Old 01-06-2021 | 06:33 AM
  #245
Shouldn't be a smart switch so you should be able to open it up, de-solder the wires that go to the switch and bridge the two corresponding pads. Good luck on re-calibrating it without disassembly though.
Old 01-06-2021 | 07:44 AM
  #246
ugh youre right about the calibration...didnt think of that maybe ill just shorten the wires and mount the switch on one side and the cap on the other.
i try to have as minimal wiring on my cars as possible.
ray4624 is offline
Old 01-16-2021 | 11:09 PM
  #247
Just got my OTA set up and went into this ESC.
Couple questions. DDRS punch rate. I assume that is just wheel spin control so if on high track carpet, put it on 9?
Also, there are several firmware options. V1_509, V1_20K, V1_17.5K. Are the last two RPM limited versions?
Silverbullet555 is offline
Old 01-26-2021 | 07:32 AM
  #248
carbons2k's Avatar
Can the HW XR10 just stock do 1s batteries? Im looking to put this into a 1/12 scale.
carbons2k is offline
Old 01-26-2021 | 09:29 AM
  #249
If you scroll over the menu on the manufacture website, they list 3 of their ESC's rated for 1S:
XR10 Stock Spec 1S - https://www.hobbywingdirect.com/prod...nt=27998511377
XR10 Pro/Modified 1S - https://www.hobbywingdirect.com/coll...s/xerun-1s-esc
billdelong is offline
Old 01-28-2021 | 04:08 AM
  #250
Just got my program box, the FW version on mine is V1_509_No Timing
