SC10 Thread
Old 12-26-2010 | 05:29 PM
  #5311
ShortCourseOnly's Avatar
Originally Posted by BigBrute_347
What do the 30 degree caster blocks do to handling? Thanks!
I would say that they calm down the steering on the chassis. I don't think they effect handling in any other way.
ShortCourseOnly is offline
Old 12-27-2010 | 11:54 AM
  #5312
bigmike22's Avatar
Originally Posted by FLHX1550
Well, sitting in Ryan's pits and looking at his truck, he had barcodes on it all the way around. Nothing modified.
You may want to look closely at his tires, notice that they are a little wider than normal? thats because he has 2-3 tires glued together.
bigmike22 is offline
Old 12-27-2010 | 01:48 PM
  #5313
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Originally Posted by bigmike22
Actually he was using custom tires he made himself. He glues 2 or 3 different tires together to get the sidewall he likes with inside tread he likes and outside tread he likes. They are pretty cool, are usually a little wider than what the normal width is, but bery pricy cutting up 3 pairs of tires to make one good pair.
Originally Posted by Cameron Kellogg
...and that's why I like spec tire racing. That would make a set of short course tires about 130 bucks
Who else wants a tire sponsor!
When the team drivers experiment like this, the hobbyists like us are rewarded with a new tire. Remember the Losi BK Bars? It's this type of experimentation that gives us new stuff to buy!
Anyhoo, speakin of tires. I just built my FT SC10. What's a good choice of tire for an indoor track. Packed, unswept clay. Any info will help.
SpraydbySprague is offline
Old 12-27-2010 | 05:12 PM
  #5314
tony montana's Avatar
barcodes or wishbones
tony montana is offline
Old 12-27-2010 | 05:20 PM
  #5315
RC-ZOMBIE's Avatar
LRP short course combo...Any good???
RC-ZOMBIE is offline
Old 12-27-2010 | 05:21 PM
  #5316
Zerodefect's Avatar
Originally Posted by topcat-lll
He Guys
I just bought a SC10 RTR brushless. I took it to a small track today and it handled pretty good; turned good, jumped pretty good and accelerated pretty
quickly. The only problem was getting on the gas hard out of turns. The rear-end seemed the want to break-loose; easing on the gas kinda fixed it. I might replace the grease with 7,000 wt diff fluid. One more thing. I weighed the RTR brushless Pro-Comp body and it weighed a whopping 245grams my nitro 1/8 buggy's body only weighs 55grams. Does anyone know who makes a lighter body?
The Factory Team setup is quite dialed and easy to drive, I don't use it, but it is the best place to start:
http://teamassociated.com/pdf/cars_a..._edit_2010.pdf
Try that. I use 2 degrees of rear camber instead of factory.
Don't put fluid in your gear diff. Get the ball diff instead.
Also upgrade to the V2 slipper pads and slipper spring, then run the FT kit setting or a little less slipper. I had no luck with the old white slipper pads.
You can't get on a Sc10 very hard. If your smooth it'll reward you.
Zerodefect is offline
Old 12-27-2010 | 10:23 PM
  #5317
I got this thing to help improve my racing lines, plus everyone and their grandmother has one. Next weekend we are having a big race, (if the weather
holds out) and it will be my first race with it. I'll be racing it box stock to get
a feel of what I think needs to be changed. I'm almost sure I'll be adding some
negative camber to the rear and probably loosen the slipper clutch. I will buy
the ball diff, but will try to work with the gear diff; I raced ten years+ 1/10th
scale nitro stadium truck(losi XXX-NT) which had ball diffs a real p.i.t.a., but
will put the ball diff in if I can't get the gear diff to work right. I'm still reading
this thread I started from page one and I am at page 200 now still aways to
go so I'm still learning.
topcat-lll is offline
Old 12-28-2010 | 08:26 AM
  #5318
Registered User
Yes, it is good combo.
RustyRC is offline
Old 12-28-2010 | 08:29 AM
  #5319
I ran it all last season. It was bulletproof for me. Controllable power, yet enough.
Brandon Powell is offline
Old 12-28-2010 | 11:07 AM
  #5320
Customworksking's Avatar
im looking to buy a sc truck either the HPI or associated how does it do against the blitz ? thanx
Customworksking is offline
Old 12-28-2010 | 09:01 PM
  #5321
RUNNINONMT's Avatar
they are both very good trucks what it comes down to is the setup, and how good of a driver you are. if you cant do either than you will lose with both.
RUNNINONMT is offline
Old 12-28-2010 | 09:22 PM
  #5322
Smile
I know that so,it will b whatever deal I get 1st.. thanx
Old 12-29-2010 | 03:01 PM
  #5323
bajabro's Avatar
Which side of the tranny is the ball diff screw head supposed to be on?
bajabro is offline
Old 12-29-2010 | 03:04 PM
  #5324
Cameron Kellogg's Avatar
AE says same side as the spur gear. (Right Side) I run mine of the left side and have not had any issue with the screw backing off.
Cameron Kellogg is offline
Old 12-29-2010 | 03:11 PM
  #5325
bajabro's Avatar
ok thanks
bajabro is offline
