SC10 Thread
Old 12-18-2010 | 08:53 PM
  #5281
Zerodefect's Avatar
Originally Posted by cheeks8
hello this is my first post on this site i go mainly on hobbytalk been looking to get my sc10 working better its a bit beat up from alot of racing the past year. I never had a ball diff in my truck as far as i know its been with a few owners before me and i never took it apart yet does it make a differance at all. ttul
Cheeks
What did u do with Cheeks 1-7?
Tampa Bay?
Zerodefect is offline
Old 12-19-2010 | 09:39 AM
  #5282
Smile cheeks 1-7
i dont get it
cheeks8 is offline
Old 12-19-2010 | 09:54 AM
  #5283
racer1812's Avatar
Super Moderator
your name cheeks8, what happend to cheeks1, cheeks2, cheeks3? get it?
racer1812 is offline
Old 12-19-2010 | 04:06 PM
  #5284
RUNNINONMT's Avatar
The cheeks were hungry so they 8. I keed i keed welcome to rctech cheeks8.
RUNNINONMT is offline
Old 12-20-2010 | 06:36 AM
  #5285
pakk's Avatar
any trick to freeing up the gear diff? I took mine apart to clean it and put fresh black grease and it didn't help much. I didn't put very much either. I think I want a ball diff, but I thought I'd ask first.
pakk is offline
Old 12-20-2010 | 07:01 AM
  #5286
Csaari77's Avatar
The more you run the diff, the more it should free up. The black grease will start to break down with use.
Csaari77 is offline
Old 12-20-2010 | 09:37 AM
  #5287
Default sc10
I just purchase a new Team Associated SC10 RTR Rockstar yet I am looking for speed. It comes equip with SC XP 450-BL esc and 3300 brushless Reedy motor.. I want to race against my friends which have Traxxas Slash with VXL.. What kind of motor should I get to compete? I know they sale a Reedy 6100 motor would it work with stock esc?
Thanks for the help
reyesjhs is offline
Old 12-20-2010 | 09:47 AM
  #5288
Thanks for the help
If you are racing on an actual track then the 3300 motor has enough power, just pick up some more pinion gears. Anybody know what comes as the stock pinion?
Krio is offline
Old 12-20-2010 | 09:56 AM
  #5289
rally4u's Avatar
an 18 tooth,lock the slipper and put in a 22 tooth it will do wheelies and go pretty quick
rally4u is offline
Old 12-20-2010 | 10:26 AM
  #5290
BuggyKing's Avatar
Yes I ran 2 of the 4 spider gears. I also removed the the very small seals on the outdrive as to these will bin the diff if they get damaged. Lastely I just coated the gears with 100k OFNA diff oil. Worked very well on the track for me.
BuggyKing is offline
Old 12-20-2010 | 03:27 PM
  #5291
pakk's Avatar
When I was going through it, I did notice that a lot of the resistance was coming from the outdrive seals. Both of the seals looked to be in good shape though.
Are you getting any leaks with the seals removed?
What turn motor are you running? Will two of the gears hold up to an 8.5?
pakk is offline
Old 12-20-2010 | 08:09 PM
  #5292
Default Sc10 gears
I just picked up a used sc10. What should the stock pinion and spur gear be for the reedy motor?
Randy
ralaco is offline
Old 12-20-2010 | 08:38 PM
  #5293
Default which motor
castle creations 3800 4 pole will do it, and your friends will burn up there motor getting hot where 3800 will run cold
mfcoupe32 is offline
Old 12-20-2010 | 09:12 PM
  #5294
WillD's Avatar
Originally Posted by T-BirdJunkie
3k indoor, 5k loose outdoor track
ditto, the 5k oil worked great in my diff this past season at my home track which is loose
WillD is offline
Old 12-21-2010 | 06:19 AM
  #5295
Registered User
Randy
Brushed or brushless? 30,000rpm or 3300kv?
If it is brushed, it should be left on factory setting 18/87 since it has been running some hot. I think it is better off to get brushless motor. For brushless motor, It can be between 18 to 20t and check your temp. on motor.
RustyRC is offline
