RC10B4.1 FT/WC
Old 11-02-2010 | 06:26 PM
  #766
rc east's Avatar
Also had to notch the shock tower for shock cap clearance after drilling the fourth hole.
rc east is offline
Old 11-02-2010 | 08:12 PM
  #767
Ok, I'm looking for some more on power steering with my buggy...
Running the FT B4.1 kit setup with the following changes...
Front:
-2 Camber
top shock moved to inside
Rear:
-0.5 Camber
2.5 deg toe block with the 0.5 hubs.
Battery is as far forward as possible. No weight has been added.
Suggestions?
Slashdrivr is offline
Old 11-02-2010 | 08:57 PM
  #768
1Fastpede's Avatar
Front:
-2 Camber
Rear:
-0.5 Camber
Suggestions?
i found good steering with a 1/4 oz stuck to the bulkhead but would love more!
1Fastpede is offline
Old 11-02-2010 | 09:19 PM
  #769
RA99GT's Avatar
u don't need to do that. the inside hole on the b4.1 tower is the drilled "4th" hole on the b4 tower
RA99GT is offline
Old 11-03-2010 | 05:48 AM
  #770
rc east's Avatar
Yes but not on the T4.1, sorry
rc east is offline
Old 11-03-2010 | 05:13 PM
  #771
RA99GT's Avatar
my bad. didn't realize you were talking about the truck.
RA99GT is offline
Old 11-03-2010 | 05:51 PM
  #772
Can anyone give me any feedback on the B4.1 brushless RTR as a racer? Obviously I'm not expecting it to be a title winning car, but can it hold its own in the right hands? Just looking for a cheap 2wd to run, and the fact it has everything out of the box (motor,esc,radio etc), it a pretty tempting buggy to buy for a bit of fun on the side to my nitro buggy.
Is the motor/esc pretty decent? Any common issues with any of th car?
thorns is offline
Old 11-03-2010 | 06:16 PM
  #773
gas-man's Avatar
Does a T4 body fit a T4.1 truck?
gas-man is offline
Old 11-03-2010 | 06:19 PM
  #774
mattleegee's Avatar
Its a decent setup to get started (i got the t4.1 RTR kit) the 3300kv motor is about a 13.5t motor and holds its own. I used my setup for about a month before i started upgrading, i still got some decent money selling the stuff because they arent "bad" products
Problem with it is its sensorless and once you drive sensored you will want to upgrade ie-better control of power with sensored
The radio, i never liked the radio... Uses 8 AA so it weighs alot and it sucks the batteries right up. Plus analog adjust is garbage. It gets the job done though
mattleegee is offline
  #775
mattleegee's Avatar
Yes
Old 11-04-2010 | 08:36 AM
  #776
Ae*Driver*70's Avatar
Default AE Is Killer Of All......
What Deg toe block used for Blue Groove tracks would you use in the Buggy?
Ae*Driver*70 is offline
Old 11-04-2010 | 10:08 AM
  #777
Anthony.L's Avatar
Try 0*
Anthony.L is offline
Old 11-04-2010 | 10:57 AM
  #778
racer1812's Avatar
Super Moderator
Originally Posted by Anthony.L
Try 0*
He said toe block, did you mean 0* hubs? I don't run BG so I can't help ya..
racer1812 is offline
Old 11-04-2010 | 12:04 PM
  #779
I would start at 3* toe block with 0* hubs.
DanGriffin is offline
Old 11-04-2010 | 12:14 PM
  #780
PIIHB!'s Avatar
What would a good starting point on gearing (b4.1) for the sidewinder 4600 on a medium size track? I'm just looking to see if i need to pick up any more pinion gears...
Also any servo recommendation's? I dont know what speed and torque to look for.
PIIHB! is offline
