8T 2.0
Old 10-18-2010 | 02:57 PM
  #9721
Integra's Avatar
Originally Posted by hambone
It's pronounced jabroni.
Integra is offline
  #9722
smokinu's Avatar
Mon morning humor. And i'm not a fan.
just wondering, but with people like tc5man and druex around its hard to tell!
See you this weekend Frankie! been a long time! since the Italian stallion and i have been at the same track!
smokinu is offline
Old 10-18-2010 | 03:10 PM
  #9723
JAMMINKRAZY's Avatar
Some Fioroni stuff rocks. The rest is overpriced garbage. That's just how Fioroni is.
Awesome carnage there Frankie! Looks like someone has some work to do. Aluminum in the drivetrain, especially in a truggy = bad idea!
JAMMINKRAZY is offline
Old 10-18-2010 | 03:27 PM
  #9724
tc5 man's Avatar
Tech Prophet
ok ?
tc5 man is offline
Old 10-18-2010 | 04:25 PM
  #9725
Frank L's Avatar
I did it to both cars alum'ed them out and well axles were a very bad idea unless you change them frequently. I had a wheel fly off, went to pick it up and the nut was still attached the alum axle on the buggy cracked in 1/2. Going back to the steel stuff.
Frank L is offline
Old 10-18-2010 | 04:32 PM
  #9726
smokinu's Avatar
hey Frank, didnt you have this talk about all the light stuff with your buggy when you got it last year?
smokinu is offline
Old 10-18-2010 | 05:21 PM
  #9727
Frank L's Avatar
Ya Ya Ya....
Frank L is offline
Old 10-18-2010 | 05:54 PM
  #9728
Oasis's Avatar
I just stick to stock unless the aftermarket stuff is stronger, then I'll switch to the stronger parts.
So you guys going to be at CVR this weekend?
Oasis is offline
Old 10-18-2010 | 05:56 PM
  #9729
Ya Ya Ya....
Old 10-18-2010 | 06:03 PM
  #9730
rider313's Avatar
hey guys i was going threw my truck today and notice the rear arms were binding at the inner hinge pin mounts. the pins are not bent, but while in the arm they dont move very free causing them to not want to drop free. So i think i need to clean the hole out in the arm what size drill bit do i need?
rider313 is offline
Old 10-18-2010 | 06:28 PM
  #9731
smokinu's Avatar
there will be a few of us. although i dont drive a losi. but i like hangin out with frank and the cold fusion crew! bunch of shit talking hackerz!
But its all in good fun!
smokinu is offline
Old 10-18-2010 | 06:33 PM
  #9732
losi_racer's Avatar
use a 4mm arm reamer
losi_racer is offline
Old 10-18-2010 | 07:40 PM
  #9733
Frank L's Avatar
Ill be there.
Frank L is offline
Old 10-18-2010 | 07:44 PM
  #9734
juggaloracer198's Avatar
Questions??
WHAT SIZE REAR CAMBER TURNBUCKLE DO I NEED TO HAVE TO RUN THE V2??
92MM OR 98 MM???
juggaloracer198 is offline
Old 10-18-2010 | 07:45 PM
  #9735
i use a 11/32 drill bit. it is just a hair larger than the 4mm, but the pins wont bind up while your racing if some dirt gets in.
nitroal is offline
