8T 2.0
Old 07-26-2010 | 06:36 PM
  #8221
99problems's Avatar
Thumbs up
Grinding those spindles changes the game completely
99problems is offline
Old 07-26-2010 | 06:37 PM
  #8222
losi_racer's Avatar
yes nick thanks. i started doing this before the 10 degree caster blocks came out, thanks to Billy Fisher. I didnt like to run the alum spindles due when i changed the bearings out the bearings would have such a tight fit i had a very hard time taking them out. When Billy told me at nitro challenge he ran the plastic spindles but dremeled out i tired it and i love it, it gave me just a little more turn it but enough to make it worth it. btw im still on the same spindles as when i dremeled it.
btw i had that setup in a pdf if ppl are having a hard time seeing it, converting it to jpeg took a lot of quality away. Email me if u want it [email protected]
losi_racer is offline
Old 07-26-2010 | 06:49 PM
  #8223
l3asher's Avatar
Default Old vs New Diff cups
How do you tell them apart? My stock 2.0 has a silver looking washer made in to the cup. I have another diff cup that does not. The out sides also look like they are made different.
l3asher is offline
Old 07-26-2010 | 06:56 PM
  #8224
JAMMINKRAZY's Avatar
The outsides are different. The old ones are completely round on the end where the ring gear goes. The new ones have sort of "cut outs" around the outside. You can see bits of the blue paper gasket on the new ones when assembled. Don't know if that makes any sense.
JAMMINKRAZY is offline
Old 07-26-2010 | 07:22 PM
  #8225
Integra's Avatar
it does.
Integra is offline
Old 07-26-2010 | 07:54 PM
  #8226
losi_racer's Avatar
btw, you can take that washer out.you dont need it
Old 07-26-2010 | 10:24 PM
  #8227
I think he's talking about the steel insert that is molded into the plastic diff cup where the bearing/outdrive rides. Some are silver, some are black. That's the only difference I know of with that piece.
Old 07-27-2010 | 05:09 AM
  #8228
l3asher's Avatar
Correct, silver is on the new style cup and the black is on the old style on the two I have right here.
l3asher is offline
Old 07-27-2010 | 02:23 PM
  #8229
losi_racer's Avatar
misunderstood thanks
Old 07-27-2010 | 02:34 PM
  #8230
teamlosi906's Avatar
Default losi
Whats the difference, between the 10 and the 12 degree inclined spindle sets. For the 2.0 truggy Is one better for slicker tracks?? thanks for any info. 1 of my friends runs the 12 degree and loves them .
teamlosi906 is offline
Old 07-27-2010 | 02:51 PM
  #8231
12 degree spindle carriers have 12 degrees of caster. 10 degree carriers have 10 degrees of caster. More caster will decrease off power steering entering a corner, and increase on power steering mid corner and exit. Less caster will increase off power steering entering a corner, and decrease on power steering mid and exit. The 12 degree carriers will smooth out the off power turn in and provide a bit more on power steering. 10 degree carriers(Stock caster) will make the steering more responsive and increase off power turn in.
Old 07-27-2010 | 03:25 PM
  #8232
losi_racer's Avatar
i still wish they made them in plastic.
Old 07-27-2010 | 05:14 PM
  #8233
pballer2777's Avatar
hell yeah!!
pballer2777 is offline
Old 07-27-2010 | 06:08 PM
  #8234
sluggo_sx8's Avatar
here ya go,
when i say i dremeled the front spidles i dremeled out the inside corner to allow more steering
do you have a pic of the area dremeled??
sluggo_sx8 is offline
Old 07-27-2010 | 06:24 PM
  #8235
losi_racer's Avatar
Originally Posted by Integra
This is Courtesy of Mr Drake.
here, same spot on the original plastic spindles
