Team Associated RC8Be Thread >
Old 10-10-2010 | 11:40 PM
  #541
dickie doyle's Avatar
Originally Posted by helmsey
Question about the elite mount I just got.... with the pinion installed it is not lining up correctly with the spur....close, but not exactly. below is a horrible cell phone pic....
Am I good to run this like it sits until i can get a pinion with a shorter shank??
Can't you just flip the pinion 180deg??
dickie doyle is offline
Old 10-10-2010 | 11:44 PM
  #542
Anyone found Mayfields setup sheet from the Nats?? Think it'll ever be public info?? His car was dialed, saw it with my own eyes!
Old 10-10-2010 | 11:54 PM
  #543
You have about half the teeth lined up so you could run like this but you are risking stripping the spur gear. It is your gear, your call.
Ostach24 is offline
Old 10-10-2010 | 11:59 PM
  #544
tq_danpatterson's Avatar
Nope. Motor shafts are not that long.
tq_danpatterson is offline
Old 10-11-2010 | 12:05 AM
  #545
TomTomTuning's Avatar
Seems to be a common issue with them... I found another photo of someones elite mount...
I would maybe call elite up and see what they say.
TomTomTuning is offline
Old 10-11-2010 | 12:21 AM
  #546
haha thats funny that maifield is running the same weird offset on the spur. I am sure by now he has a different pinion but still funny.
Ostach24 is offline
Old 10-11-2010 | 05:59 AM
  #547
helmsey's Avatar
Tried that but the set screw would not be on the motor shaft all the way. I'll have my new pinions this week so I'll be able to run this weekend
helmsey is offline
Old 10-11-2010 | 06:01 AM
  #548
longbill76's Avatar
Hey Guys, my pinion of choice is either HotBodies or Robinson Racing, they have the shortest shank bodies which works best with my mounts.. I prefer HotBodies cause they have the shortest shank, they're lightened and also cheaper..
longbill76 is offline
Old 10-11-2010 | 06:15 AM
  #549
I'm using Losi Mod 1 pinions and they work fine with my Elite motor mount. I have the entire pinion in contact with the entire spur gear. I'll try to get some pictures posted this evening.
Wease is offline
Old 10-11-2010 | 07:30 AM
  #550
Taffyjnr5's Avatar
Hi,
I am looking at picking up a SP 7.5R silver arrow 1/8 brushless motor and would like to know what is the Kv rating for this motor is?
Taffyjnr5 is offline
Old 10-12-2010 | 02:21 PM
  #551
Default Bending front CVA bones
Anyone else bending the front CVA bones in there RC8B or RC8Be? I've only raced mine two weekends in a small indoor facility and I've already bent both front CVA bones . I'm a better than average driver, so It's not like I'm banging walls and tubes all the way around the track. The kit was built from new so its not as if these CVA bones have a lot of time on them either.
I checked with a couple of other local guys who race the RC8B and RC8Be and they report similar problems. I went to order these from A Main and they're out of stock which might indicate this part is in high demand for the same reason.
At $20+ a pair, this is not the type of part I expect to be considered wear and tear if you know what I mean, grrrr!!!
Wease is offline
Old 10-12-2010 | 02:28 PM
  #552
Man, I am getting one of these toward the end of the month. They are on back order everywhere. I hope someone comes up with a solution by the time mine arrives because I cant keep replacing them that often either.
devilsquid is offline
Old 10-12-2010 | 02:36 PM
  #553
Ed237's Avatar
I've had good luck bending CVAs back into place.
I read somewhere that the Thunder Tiger S3 CVA's might work.
Ed237 is offline
Old 10-12-2010 | 02:41 PM
  #554
You can be unlucky and bend them but dont throw them out you just bend them back.It is pretty easy and with a few minutes of slowly working them you can get them close to perfect. They have been that way since day one .
ace955 is offline
Old 10-12-2010 | 03:39 PM
  #555
ses601's Avatar
i bent the left front the second time i drove the car, and i've been running it that way since june it's not a severe bend, but i'm just trying to give you an idea of what you can get away with!
ses601 is offline
