Like Tree2Likes
Go-Tech Engines Thread
Old 09-20-2010 | 06:59 PM
  #11926
Do-Over's Avatar
Never got a response on the fuel question. I'll ask again. Will it be too bad to use the 1/2 gallon of A-main 25% on breakin? I just hate to waste it and I can only get it about once a month when I see a certain parts guy...
Do-Over is offline
Old 09-20-2010 | 07:03 PM
  #11927
deadmancourt's Avatar
you should be fine...what % and brand do you plan on running after the half gallon is gone?...
deadmancourt is offline
  #11928
i would think that would be fine, as long as you break it fully in with same fuel
inferno13 is offline
Old 09-20-2010 | 07:19 PM
  #11929
Do-Over's Avatar
I love the A-main and I want to continue running it was just gonna go to 30% after the 1/2 gallon and the hardest part of run in is over. It's made by MM so it should be good for these engines I would assume.
So you think I would have to continue running 25% after that 1/2 gallon Inferno?
Do-Over is offline
Old 09-20-2010 | 07:24 PM
  #11930
grizz1's Avatar
25% will be fine. I run all my motors in on 25% and then race on 25% or 30%. Maybe just lay of going to the 30% until you have a gallon through the motor.
The newer GX motors will spin over fine if you heat them. The older Pro series motors were a bit of a nightmare, but GO has the tolerances on these new motors spot on. They are easy to run in, but still tight enough to give great performance for a long life span. Just be patient and do the 12 - 15 tanks. It will be a little funky for the first couple of tanks, but after 3 tanks it should be running nice and smooth. You don't want to baby it too much, and after 8 tanks you should be starting to feed it a little fat. You will feel when the motor is starting to free up and wanting to rev higher. Just make make sure you heat it up nicely for these first tanks and it will love you back when it gets older and a bit worn Ideally you should heat it everytime you start it from cold, this will increase your motors life exponentially. But this is not always practicle at the track, but if you can, do it for sure.
Let us know how you get on
grizz1 is offline
Old 09-20-2010 | 07:25 PM
  #11931
jwm2's Avatar
You'll be fine on 30%, you just might have to retune it alittle, but it won't be a big deal. I tend to mix my fuels 50/50 right before i switch, it makes the transition alittle easier.
jwm2 is offline
Old 09-20-2010 | 07:28 PM
  #11932
no, but i would break it in on same fuel, then switch from there.
Old 09-20-2010 | 07:29 PM
  #11933
Do-Over's Avatar
Can you explain that Grizz? I've been hoping you'd show up soon!
Do-Over is offline
Old 09-20-2010 | 07:38 PM
  #11934
"feed it fat" run it rich with a crap ton of smoke...lol
Old 09-20-2010 | 07:46 PM
  #11935
Flanno's Avatar
You know it
I'v never seen the point of going to 30% myself, I get great performance from my 25%, but everyone has a different opinion on this. So its your call.
I personally would stay on 25% and just remove a .1 shim after 5 litres to get the same performance as 30%.
Flanno is offline
Old 09-20-2010 | 07:50 PM
  #11936
Originally Posted by Flanno
You know it
so you are running .4mm of shim on 25%?..
Old 09-20-2010 | 07:51 PM
  #11937
You know it
i personally run 30%, but like you said, really a personal preference!
Old 09-20-2010 | 08:00 PM
  #11938
Do-Over's Avatar
I know fat is rich but shouldn't it be rich for run in anyway? That's why I didn't understand why he said that as it should be a little rich anyway.... Just thought it might be a different circumstance.
I may stay with the 25% after hearing that. I've just never got to run 30% before and everyone else does. lol kinda silly sounding when I type it out.
Do-Over is offline
Old 09-20-2010 | 08:11 PM
  #11939
grizz1's Avatar
Perhaps that wasn't the best phrase to use. It means ¨give it some throttle¨ or ¨put the foot down¨ - nothing to do with running rich.
You want to be a little on the rich side while running in, but not real rich and boggy. Just a little blubbery for those first 8 tanks, then a little leaner for the next 4, then just under race tune for a few more. Then by #15 you should be ready to race. It will still be tight for a while, so don't expect 100% performance or real good economy for at least 1.5 gallons. By then you should be humming real good
grizz1 is offline
Old 09-20-2010 | 08:13 PM
  #11940
Do-Over's Avatar
That's why I asked. I didn't think you meant rich but I didn't know what you actually meant either....
Do-Over is offline
