Team Associated RC8Be Thread >
Old 08-20-2010 | 09:57 PM
  #241
Michael#81's Avatar
My RC8BE with new paint and decals and ready for the Futaba Electric Challenge. Paint by Larry @ Kustom RC Graphics and the decals and wing wrap by Chad @ Fastlane Graphix.
Michael#81 is offline
Old 08-20-2010 | 11:56 PM
  #242
Originally Posted by jboquire
I used it in my truggy, good fit and perfect match to the Losi tray. On my rc8be, I'm going with foam tape and switchless for weight saving purposes.
Jb
i cut my switch too and added foam underneath the esc then bolted it down!
its gonna be the first time to run it tomorrow night. little nervous cus i come from the 1/10 electric scene just dont know what to expect i guess. i hear its a animal though lol
toyota 2jz is offline
Old 08-20-2010 | 11:58 PM
  #243
sick man!! i have larry do all my bodies as well
Old 08-21-2010 | 12:01 AM
  #244
Michael#81's Avatar
This is what I use to mount my ESC. It is super sticky and very flexible. I also take a couple small zip ties and run them over the ESC just to hold it in place.
http://www.amainhobbies.com/product_...ng-Gel-1-Sheet
Old 08-21-2010 | 06:50 AM
  #245
pvalenti's Avatar
There's a pic of my RC8Be. I thought that the build went VERY smoothly...and that's coming from a guy who's NEVER built a KIT RC before. Sure I made a few mistakes and had to redo a step or two. But I learned a LOT that I wouldn't have had I decided to go with an RTR.
It drives like a DREAM and immediately made me feel like a HERO!
My gear-
MMM w/ Castle/Neu 1512 1.5y (1800kv)
CC BEC
HiTec HS7950
Airtronics 92744 RX
Gearing is currently 20/46
I'm running 2- Tenergy 5200Mah 2S 25C Lipos in series (4S)
I'm pretty much running the stock setup with a few changes. I've switched to Ghea 3059 8x1.3mm tapered shock pistons and I've switched to Losi 32.5 oil all the way around. So far...so good!
pvalenti is offline
Old 08-21-2010 | 07:18 AM
  #246
[/IMG]
Sweet ride...
I just finished my RC8Be build recently and now I'm just waiting on my DX3S to arrive so I can put in the receiver. I'm going to give a rattle can paint job a try but I'll probably also end up sending a JConcepts body to Kustom RC Graphics; I really like his work.
Question, what body did you use on this buggy?
Also, what do you guys do to prevent wires or the sides of the chassis from scratching up the undercoat paint on your bodies? Someone had suggested using tape to protect against chassis scratches but I was just wondering if that's what most folks use.
MulliganAl is offline
Old 08-21-2010 | 07:41 AM
  #247
Arigato's Avatar
I've tried duct tape and heat tape, but found that shoe goo works best.
Arigato is offline
Old 08-21-2010 | 10:01 AM
  #248
Michael#81's Avatar
Sweet ride...
Thanks. That is a Proline Bulldog body.
I don't use anything special for the sides. I always velcro both sides of the body to the side of the chassis so it doesn't rub. My wires on the inside do not rub the body at all the way I have it all soldered up.
On my SC body where I know stuff is going to rub I take a thin layer of shoe goo and rub it on the inside so it rubs away at that instead of the paint.
Old 08-21-2010 | 12:36 PM
  #249
Default chassis selection
I've been very interested in a new chassis lately. I'd like to give that snr carbon one a shot but its expensive to say the least. I wondered if I could have anyone that knows give a few reviews and specs on the chassis currently available.
FT- the previous post says 12oz but I weighed my rtr chassis and it comes in at 10.46 so that seems off. Even the mud guards only weigh 1.43 together so thats close but not sure how it was weighed
SNR- he posted at 6.5 oz
BCE-?
Fironi-?
RC-Monster-?
hontrx265r is offline
Old 08-21-2010 | 04:39 PM
  #250
JASON671's Avatar
what are some good/lowcost lipos that will fit the rc8be? im looking for a 4s pack.
JASON671 is offline
Old 08-21-2010 | 05:25 PM
  #251
millerdui's Avatar
if you get more than one pack the hobbycity.com turnigy packs ar good. I have 3 4s5000mah for my truggy. A lil heavy though, you can cut some of the wire and save a few grams and maybe get them down to 500-515g
millerdui is offline
Old 08-21-2010 | 05:51 PM
  #252
brickshouse's Avatar
Default rear diff bearings
I keep blowing out my left rear diff bearing, new case, shimmed right, it has always felt kinda loose, is this common or is something wrong? Thought it may be an outdrive, replaced it, but after every race, about 45min. give or take, the left side outdrive has a buttload of play(back and forth). It is worse afterthan before i run it, first tried ae bearings, then went to protek with same results, new to 1/8 so need some advice, thanks
brickshouse is offline
Old 08-21-2010 | 08:28 PM
  #253
snrscion's Avatar
Registered User
BCE-?
Fironi-?
RC-Monster-?
You got to understand it 140 shipped. The shipping alone is 10 to 15 dollars priority mail anywhere in the USA.
Sorry for the miss calculation but it 6.6 oz. I can even make it lighter if I cut more material of like the flywheel and spur gear hole and drill out all the hole that is one the stock chassis.
snrscion is offline
Old 08-21-2010 | 11:21 PM
  #254
Default chassis
Like I said I'll probably try one out. How about some "B" shock towers?
Old 08-21-2010 | 11:23 PM
  #255
raced my rc8be tonight and took 3rd car is a dream to drive and lovin it!! its my first time driving 1/8 ever too lol
