The Speed Passion Thread >
Like Tree57Likes
Old 08-12-2010 | 06:52 PM
  #5176
Marcos.J's Avatar
Super Moderator
Originally Posted by S.A.W
Ok thanks.
May I ask why you use 5.7 for 13.5 when all the files/documents are recommending around 6.25 - 7.00 ? please don't think I'm saying your setting is wrong but this is where I am getting confused with gearing it correctly and why I asked earlier if there was a suggested setting.
The manual with the motor recommends 4.8 -6.0 the SP Basic Supercharger setting PDF say's 6.25-7.0 and then the Word doc say's 6.5-7.0
I never know which to start with I presume you've tried loads of different fdr's ?
Thanks.
the 422 and the 528 are different softwares you cant use the same gearing suggestions,
Marcos.J is offline
Old 08-12-2010 | 06:58 PM
  #5177
shesha's Avatar
Hey guys
Am checking my SP GT2.0 Carbon Edition on the USb interface software V1.33
Checkin the software version that is runnin on the ESC as it is now shows V1.10_090205_MOD did Speed passion a latest software I can upgrade to and if there is what are the benefits.
shesha is offline
Old 08-12-2010 | 07:44 PM
  #5178
defcone's Avatar
Originally Posted by shesha
Hey guys
If you're running mod and the track size is a medium-ish you won't notice much difference between 205 and the 528_MOD.
But if you're running a stock motor, 10.5t and higher you will notice a huge difference between 205_g and the stock softwares.
defcone is offline
Old 08-12-2010 | 07:53 PM
  #5179
mr crum's Avatar
Ok thanks.
Thanks.
hey saw i was running my 13.5 at 6.46 fdr and went up to 5.76 and the car had more bottom end way more top with cooler temps
mr crum is offline
Old 08-13-2010 | 12:51 AM
  #5180
Thanks very much Marcos.J and irgo
Marcos would you use the same speedo settings for indoors and just change the gearing ?
Simon.
S.A.W is offline
Old 08-13-2010 | 05:59 AM
  #5181
Marcos.J's Avatar
Super Moderator
Simon.
yes pretty much
here are my settings for indoors with a 17.5
Marcos.J is offline
Old 08-13-2010 | 06:11 AM
  #5182
Originally Posted by Marcos.J
yes pretty much
Thankyou.
S.A.W is offline
Old 08-13-2010 | 08:38 AM
  #5183
I looking for settings for a 4wd off road. Running a kyosho zx-5 sp, and a ballistic 10.5 what's a steering point?
Tha Skinny is offline
Old 08-13-2010 | 08:42 AM
  #5184
Max everything cracker,gear it up until the motor wires unsolder then drop 1 tooth,what are you doing dude?Heading back anytime soon?
steve eaves is offline
Old 08-13-2010 | 08:52 AM
  #5185
Ha lol... Call me man!
Old 08-13-2010 | 09:16 AM
  #5186
shesha's Avatar
shesha is offline
Old 08-13-2010 | 09:50 AM
  #5187
RCHR Racer's Avatar
Start with default settings for 528 stock, use a 25 pinion and check heat from there. That's your staring point
RCHR Racer is offline
Old 08-13-2010 | 07:25 PM
  #5188
BAM Motorsports's Avatar
g'day just bought a new speedpassion gt v2.1 for my sc 10 it has a 13.5t xcelorin motor
just woundering what's a good starting point for the esc
i've been running the Speed Passion EXIGE Brushless ESC & Motor for the last 2.5 years in various offroad vehicles, but after a huge crash about 6 weeks ago esc and motor were both damaged beond repair
BAM Motorsports is offline
Old 08-15-2010 | 09:01 AM
  #5189
RCHR Racer's Avatar
Start with a 24 pinion on your truck with a 2.6 tranny ratio. Stock spur
Old 08-15-2010 | 08:30 PM
  #5190
skypilot's Avatar
Originally Posted by g12314
Attached is the .PDF of my BIG track settings.
PLEASE NOTE: I run the R1 Wurks dual motor fan, so please be careful with your gearing & ESC Settings. Run for a minute and check to make sure the temps are not getting too high.
Any questions, please post here or PM me. Here is a video of the track and some testing: http://www.youtube.com/watch?v=cX53c...eature=related
Jimmy
This weekend was our Tracks 26th year of putting on our summer sizzler, using the above setting I was able to secure TQ but due to a few driver boo boos finish 2nd overall, very very fast. However I did use a 12mm rotor as the silver one reached 195 in testing, the 12mm seemed as fast temps were high about 175, but I felt it wouldn't have a melt down going on pass experience. thanks for sharing. After this weekend, I am 100% sure that I had a faulty esc at nats, that and my driving sucked.
skypilot is offline
