The Speed Passion Thread >
Like Tree57Likes
Old 03-17-2010 | 08:53 AM
  #3316
Originally Posted by abailey21
Hey dude, make sure Shawn gets this at [email protected] and make sure he gets this posted for all to use.
Hold on...I talked to Andrea and he is doing a revision on the setup sheet.
Solara is offline
Old 03-17-2010 | 08:54 AM
  #3317
Originally Posted by Shawn Palmer
TRF4:
ronaldo:
231 for 10.5. it is slightly milder than 231. 10.5 is right on the edge of "OK" to use supercharger settings - be very very careful.
For 13.5 you can use either 230 0r 231.
so the 107/110 does not have supercharger settings ? Am i right to say 230/231 is the better and upgraded version of 107/110?
ronaldo-1234 is offline
Old 03-17-2010 | 08:58 AM
  #3318
racerb's Avatar
no 107/110 does not have super charger..... 230/231 does have it!! use at own risk is what they say
racerb is offline
Old 03-17-2010 | 09:00 AM
  #3319
Shawn Palmer's Avatar
ronaldo:
Correct on both, yes.
racerb:
just keep experimenting till you find a sweet spot - then let everyone else know
jixx:
For mod, the standard software that came on the ESC is best.
Gearing depends on the track, your driving style, car setup - everything. Start with about a 20t pinion and work from there - use lap times to tell you if you are going the right or wrong way with settings and gearing.
Shawn Palmer is offline
Old 03-17-2010 | 09:08 AM
  #3320
Repost for the link to the BETA software:
http://rapidshare.com/files/36249319...arger_Beta.zip
Old 03-17-2010 | 09:21 AM
  #3321
racerb's Avatar
racerb:
ya no worries.... I just a little nervous as this my first brushless system.... and there is a crap load of numbers/adjustments
I have tried to take your recomendations and inset them with what some other guy's settings are (which are totaly different by the way... which is to be expected)
racerb is offline
Old 03-17-2010 | 09:38 AM
  #3322
Born2Run's Avatar
How many settings do you have on menu #15? I have only 6.
Born2Run is offline
Old 03-17-2010 | 10:08 AM
  #3323
skypilot's Avatar
6 is correct
skypilot is offline
Old 03-17-2010 | 10:23 AM
  #3324
Born2Run's Avatar
I'm confused.I tried both 320 and 321.On 321 i can feel very easy when the turbo kicks but no on 320 as it looks more linear.On 321 when i set on #12 the 1 (Supercharger boost level OFF) i still have the feeling of the turbo kick.On 320 must be the same as the motor sound doesn't change at all. Has anybody noticed something similar?
Born2Run is offline
Old 03-17-2010 | 11:17 AM
  #3325
cherry2blost's Avatar
Just a thought but it could be where the timing is coming in still, if you remember on 110 there was a 'cogging' effect when it stepped from sensored to sensorless at about 1/3 throttle, could be related because on my speedo it used to feel a bit like a 'turbo' function when the timing kicked in, may just be doing it in a different way due to the other new parameters?
Dunno kinda makes some perverse sense to me.
cherry2blost is offline
Old 03-17-2010 | 11:26 AM
  #3326
Born2Run's Avatar
It sounds to me like a bug.
Born2Run is offline
Old 03-17-2010 | 12:36 PM
  #3327
racingnazy's Avatar
Default Well...
I was thinking how great it would to be "fast" this year in mod ashfault!!!..
So i strapped a 10.5 in the tc5, settings were 4,4,4, gearing of 5.45.
I walked out side with the warm sun on my face. Turned the radio on turn the car on. Bent over put the car down, and slowly applied throttle..... and holy shit a rocket down down the road.!!! I mean the foam on the tires went hard from the fricktion.... Unreal
thank you speed passion you made my day...!!!
racingnazy is offline
Old 03-17-2010 | 12:55 PM
  #3328
Your gearing looks alittle bit on the "Hot dangersous" side....but I am glad you like the software.
Solara is offline
Old 03-17-2010 | 12:58 PM
  #3329
ronaldo:
Hi Shawn
It is probably just me being dumb but in the above quote you seem to be saying
"231 for 10.5 it is slightly milder than 231" ???
Should one of those numbers be 230 and the other 231?? If so which way around?
It's just that I run 10.5 and I am awaiting my LCD programming card to come into stock at Schumacher. It will be my first adventure with the LCD programming card and I want to put the best 10.5 software onto my new GT 2.1
Keep up the excellent work and thanks
baldman666 is offline
Old 03-17-2010 | 01:12 PM
  #3330
SORRY! (too much work, too little sleep showing through...)
231 is milder than 230
230 is more intense than 231
Thanks for the kind words!
