8T 2.0
Old 03-06-2010 | 02:32 PM
  #6001
cary's Avatar
ya that's the one so you say it will not fit?
cary is offline
Old 03-06-2010 | 02:46 PM
  #6002
Frank L's Avatar
Nope that LiFe pack will not fit its too tall and too wide.
These are the max Dimensions (WxLxH): 1.75x2.05x.80 in (40x52x20mm)
Frank L is offline
Old 03-07-2010 | 12:06 AM
  #6003
ding_nz's Avatar
Originally Posted by l3asher
Do you have a link to the one you used?
I got them through cobraracing on this forum his website is
Cobra Racing
Although one of the other guys at our track just got some protek LiFePO's for his mugan - they are a little bit bigger and just fit into the battery box they also have a bigger capacity
Amain LiFePo
As a comparison cobras LiFe hump packs are dimensioned as followed
1300mAh
51mm L x 31mm W x 24mm H
The Amain ones are as follows:
1700mAh
55mm L x 31mm W x 32mm H
Hope all this helps
ding_nz is offline
Old 03-07-2010 | 05:38 AM
  #6004
Originally Posted by DG Designs
Jonski the set up sheet that comes with the instructions is the setup the truck comes with. 55 front, 56 rear
Madeazl its 7, 10, 2
Well, I took my shocks apart yesterday and they had 55 pistons in all 4 corners. Wonder if I should change the diff fluid too.
jonski is online now
Old 03-07-2010 | 08:13 AM
  #6005
probably. you picked it up used didnt you? If they changed out the pistons who knows whats in the diffs.
DG Designs is offline
Old 03-07-2010 | 09:07 AM
  #6006
Frank L's Avatar
Ya maybe there's nothing in the diffs. Always tear down a used car and set it up like you want.
Frank L is offline
Old 03-07-2010 | 10:28 AM
  #6007
I bought it new...it's a RTR 2.0.
Old 03-07-2010 | 10:58 AM
  #6008
bigjayjay1's Avatar
installed the ALU center diff very nice upgrade love the fact that the carb lines up perfectly possible binding issues gone and it looks awesome.
bigjayjay1 is offline
Old 03-07-2010 | 12:53 PM
  #6009
sicsam's Avatar
+1 I dont have one yet but im getting one
And how many people are running the 48 tooth spur gear?
sicsam is offline
Old 03-07-2010 | 01:02 PM
  #6010
JAMMINKRAZY's Avatar
I wouldn't use the 48 spur unless you are going to be using a .28 engine. The 50t gives a snappier bottom end and lacks no top end. Much better fit for a .21 engine.
And I agree, the alu. diff mount is awesome! A much needed improvement over the stock plastic unit!
JAMMINKRAZY is offline
Old 03-07-2010 | 01:09 PM
  #6011
sicsam's Avatar
[QUOTE=JAMMINKRAZY;7102929]I wouldn't use the 48 spur unless you are going to be using a .28 engine. The 50t gives a snappier bottom end and lacks no top end. Much better fit for a .21 engine.
Im running a LW drivetrain and i plan on taking more weight off. Im just trying to stop wheel spin on take off or coming out of the corners.
sicsam is offline
Old 03-07-2010 | 02:31 PM
  #6012
Integra's Avatar
I run 48T all the time....never personally liked the 50T for most tracks.
Integra is offline
Old 03-07-2010 | 03:09 PM
  #6013
Hate2Looz's Avatar
Hey guys, I'm picking up a truggy with this latest rebate from Losi so that
I have it to run for this outdoor season. Problem is, I'm gonna stay with
my GRP tuned .21 buggy engine. Any tips for clutching and gearing for this
engine to run it in a truggy? I know this engine is "soft" on the bottom but
for my driving style, it is a perfect engine for me, in my 2.0 buggy. Times
are tough and I can't be affording to go out and buy a brand new engine
so it's gonna have to work in my truggy.
Anyone?
Hate2Looz is offline
Old 03-07-2010 | 03:15 PM
  #6014
losi_racer's Avatar
Anyone?
wait till u can afford one, honestly.
ive tried many different combos of clutch, different gearing. that engine just doesnt have anything for truggy
losi_racer is offline
Old 03-07-2010 | 03:21 PM
  #6015
Anyone?
Many people used those engines in truggies. It will do fine with correct gearing, clutch and pipe. Maybe Frank can chime in on here. I know he ran GRP's for a while in his truggy. I believe most were modded, but he may still have some recommendations.
