Like Tree2Likes
Go-Tech Engines Thread
Old 11-19-2009 | 01:31 PM
  #9286
What plug would yall recommend for a GO 3 Port R engine? OS P3, OD 97T, something in between? Im running 30% nitro.
Thanks,
James W.
racer6888 is offline
Old 11-19-2009 | 01:51 PM
  #9287
Ruune's Avatar
either a Go T3 or OS P3
Ruune is offline
Old 11-19-2009 | 02:01 PM
  #9288
The O'donell one work realy good too, that's what i run on mine and it's realy cheap too
dakamat is offline
Old 11-19-2009 | 02:04 PM
  #9289
i run O'donnel one one mine, and it's cheap and work realy well
dakamat is offline
Old 11-19-2009 | 02:15 PM
  #9290
ALG
BUT.... they dont last to long, I always have problems with 97T plugs, they last around 1.5 liter, Novarossi plugs last more than that. this is on my case.
Im running the new 5 port with 7mm vent and the engine is very very good, the price-preformace ratio is GREAT!!!!!!! and the engine has a nice torque a good runtime.
give it a try if some or your are on a new engine, you will be glad of the choice.
Regards
ALG from Peru
ALG is offline
Old 11-19-2009 | 02:20 PM
  #9291
dakamat is offline
Old 11-19-2009 | 02:58 PM
  #9292
Mauve's Avatar
Default Plug for Go 3 pt Pro
I run a P4 on 25% so you may even go to a P5 on 30% or the O'Donnell equiv etc. P4 for sure though.
Mauve is offline
Old 11-19-2009 | 04:14 PM
  #9293
+1 on the P4 and P5, but you have got to
know how to tune. I've even ran a P6 before. The
colder the plug the smaller the tuning window. The
P3 does make it easier for the newer owners of GO
engines to find a descent tune and keeping them
running during the break-in process.
rageworks is offline
Old 11-19-2009 | 05:06 PM
  #9294
Mauve's Avatar
Right there with you Rageworks, I have broken all my Go's in on a P3 then chnaged to the P4 after the first couple of litres. The P3 is great for getting a good strong idle very easily however the P4 seems a bit better after its broken in and you can get a little bit better power from it on the colder plugs. In really hot conditions running on 30% I have gone to a P6 before as well but as you said, you have to be right on the ball to get the tune spot on and a small variance will yield poor results or flame outs. I love my Go motors however I have to say I am not a fan of the Go Plugs as I found went through them rather quick, where I seem to get 3-4 litres (1 US Gallon) on one plug with the OS plugs. The LRP #6 (about a P4-5) plugs aren't bad, I just had a bad run for a little bit (maybe it was just the batch) and went straight back to OS/Ninja plugs (same plug, different brand). O'Donnell plugs aren't common here in Australia so I can't comment really though from what I have read, they have been good.
With Go motors, the most common tuning problem I have found is that people tend to have a large idle gap and compensate this with a rich bottom end, with the net result of power not being up to scratch and blowing of plugs, watch this one. Pull the air filter, set you idle gap to about .7mm and tune the LSN from there and you should be giggling.
Mauve is offline
Old 11-19-2009 | 05:31 PM
  #9295
helivaguy's Avatar
Default go crank question
question for the go engine die hards..
ok i know the p/s/r are interchangable with the novarossi p5's (and some plus 21's)but are the 14mm cranks also?
basically could i use a 14mm novarossi crank in a go and vise versa)?
btw speaking about the older go engines,(dont know anything about the newer versions)but i think internally these mill are the same except the go front bearing.
thanks for any help.
helivaguy is offline
Old 11-19-2009 | 05:39 PM
  #9296
22Racer's Avatar
Yes a Go crank will swap with a p5 and alot of Novarossi's. I was just measuring a new Titanium nitrided crank today and noticed the lightened the backside of the counterweight a bit. Nice!
The Nitrided crank pin measured at .1966 inch or 4.9936 mm.
Rex
22Racer is offline
Old 11-19-2009 | 05:44 PM
  #9297
helivaguy's Avatar
Awesome..thanks Rex!
Old 11-19-2009 | 07:34 PM
  #9298
Does anyone know what the top end needle should be set to in terms of turns out. I dont like the idea of set it to "flush." That is vague in my opinion and one's flush may not be actually flush. Since you only turn it in maybe a half turn at most, I'm curious if my start point is off.
Old 11-19-2009 | 08:25 PM
  #9299
22Racer's Avatar
I think the reason they don't tell you turns out is you can damage the 0-ring or needle if you turn it in too hard. I have never check how many turns out.
Rex
22Racer is offline
Old 11-19-2009 | 10:29 PM
  #9300
Ruune's Avatar
Hey guys, as requested here is the MSRP listing of the current line of go engines:
R256P-P420SG 25 PRO Rear Exhaust Red Head $300.00
R286P-P420SG 28 PRO Rear Exhaust Red Head $330.00
GX-3R 21 Turbo Rear Exhaust Orange Head $290.00
GX-5R 21 Turbo Rear Exhaust Orange Head $330.00
GX-7R 21 Turbo Rear Exhaust Orange Head $350.00
MG66 Massive Mods MG-66 $400.00
Combos:
GX-3R+PI2072 GX-3R Combo Set (Engine/EFRA 2072/Venturi(4pcs) $355.00
GX-5R+PI2072 GX-5R Combo Set (Engine/EFRA 2072/Venturi(4pcs) $365.00
GX-7R+PI2072 GX-7R Combo Set (Engine/EFRA 2072/Venturi(4pcs) $375.00
Please keep in mind that these prices are MSRP, are subject to change, and street price will be considerably lower. Also, the combo kits list the venturi pieces (carb inserts) in the description, but both the combo and the engines themselves come with them
Ruune is offline
