Novarossi engines thread
#46
Originally posted by Manticore
check your back pressure fuel line. one of my buddies' engine has the same problem and later he found out that the back pressure fuel line was leaking that caused the engine stalling or no top end.
When you attends to a big race, just simply replace this part!
#47
maybe my fuel isn't of the best quality. when there is a black ring close to the top of the sleave does this mean my fuel is no good...or that i'm running it hot?
#48
Originally posted by VenomWorldOrder
thanks mate. i tested the fuel tube from pipe to tank. no isssues. i recently changed my tank as the old one was broken. i'll "sink test" it tommorow. this engine has been really good to me so i hope it hasn't died!
#49
i do not think you have problem with that black ring as long as your engine compression still hold true.
i guess work holidays allows me to fix these problems!
#50
Hey guys does anyone know what the factory screw settings r for a JP TS3 its just that I have put a new P/S in the thing and I need to run it in again, I have already looked in the book but I can't find it.
#52
Hi Guys,
I'm thinking of getting some Novarossi .21 on-road engines & get them tuned.
The R1 WC is the obvious choice but this has some work already done in the factory.
Is there a bog standard .21 on-raod which you could use as your base engine for tuning?
Many Thanks
Many Thanks
#53
Originally posted by click, dublin
Hi Guys,
Many Thanks
Hi Guys,
Many Thanks
#60
Originally posted by NITROJUNK
HEY Stefan:
How about in the heart of summer.. 85-95 degrees? Still Hottest plug?
HEY Stefan:
? Means complete brain meltdown! If are ºF probably a 6 or 7Tf and much depends on which kind of track you will run... Lots of backstraight at full throttle and none hairpins? Get a 7Tf... a 6Tf will give you a crisp low-end...
195Likes
