Like Tree195Likes
Novarossi engines thread
Old 12-21-2003 | 07:08 AM
  #46
Default Re: Re: JPs3 problems
Originally posted by Manticore
check your back pressure fuel line. one of my buddies' engine has the same problem and later he found out that the back pressure fuel line was leaking that caused the engine stalling or no top end.
CONFIRMS !!!!
When you attends to a big race, just simply replace this part!
GoldFinger is offline
Old 12-21-2003 | 07:13 AM
  #47
VenomWorldOrder's Avatar
thanks mate. i tested the fuel tube from pipe to tank. no isssues. i recently changed my tank as the old one was broken. i'll "sink test" it tommorow. this engine has been really good to me so i hope it hasn't died!
maybe my fuel isn't of the best quality. when there is a black ring close to the top of the sleave does this mean my fuel is no good...or that i'm running it hot?
VenomWorldOrder is offline
Old 12-21-2003 | 07:24 AM
  #48
Manticore's Avatar
Default Re: Re: Re: JPs3 problems
i do not think you have problem with that black ring as long as your engine compression still hold true.
Manticore is offline
Old 12-22-2003 | 06:02 AM
  #49
Default Re: Re: Re: Re: JPs3 problems
well the tank is fine, so is the pressure line. so hopefully next race meet.....next year. it will be fine. i found my reciever has conked it now i guess work holidays allows me to fix these problems!
Old 12-27-2003 | 03:20 AM
  #50
MTX-3 Kid's Avatar
Hey guys does anyone know what the factory screw settings r for a JP TS3 its just that I have put a new P/S in the thing and I need to run it in again, I have already looked in the book but I can't find it.
MTX-3 Kid is offline
Old 12-28-2003 | 08:54 AM
  #51
i just started breakin in my new novarossi ns12 s5. How does everybody like this engine?
mtx3racer is offline
Old 12-28-2003 | 12:05 PM
  #52
Hi Guys,
I'm thinking of getting some Novarossi .21 on-road engines & get them tuned.
The R1 WC is the obvious choice but this has some work already done in the factory.
Is there a bog standard .21 on-raod which you could use as your base engine for tuning?
Many Thanks
click, dublin is offline
Old 12-28-2003 | 01:42 PM
  #53
EdwardN's Avatar
Originally posted by click, dublin
Hi Guys,
Many Thanks
Actualy R1 WC is very good engine to work with. They still left some metall on right place, which needs to be massaged.
EdwardN is offline
Old 12-28-2003 | 07:31 PM
  #54
Slotmachine's Avatar
Talking hey
Hey topgun.........I hope you had a very nice Holliday. Let me know about the sleeve.
Slotmachine is offline
Old 12-29-2003 | 05:29 AM
  #55
Default What Glow Plug for a NS12 S5?
What does every run these engines with? im using 10% nitro.. weather in the 60-70's?
NITROJUNK is offline
Old 12-29-2003 | 05:51 AM
  #56
stefan's Avatar
I always run the hottest turbo plugs in my .12's. Usually the 5 tf
stefan is offline
Old 12-29-2003 | 05:52 AM
  #57
stefan's Avatar
Default Re: hey
The man is busy with my sleeves, leave him alone
stefan is offline
Old 12-29-2003 | 05:54 AM
  #58
HEY Stefan:
How about in the heart of summer.. 85-95 degrees? Still Hottest plug?
Old 12-29-2003 | 07:13 AM
  #59
EdwardN's Avatar
Default p/s sets
Hi guys.
Everybody will get on time!
EdwardN is offline
Old 12-29-2003 | 10:15 AM
  #60
Corse-R's Avatar
Originally posted by NITROJUNK
HEY Stefan:
85-95ºC ? Means complete brain meltdown! If are ºF probably a 6 or 7Tf and much depends on which kind of track you will run... Lots of backstraight at full throttle and none hairpins? Get a 7Tf... a 6Tf will give you a crisp low-end...
Corse-R is offline
