Engine richens after refueling >
Old 09-06-2009 | 06:20 AM
vti-chris's Avatar
Default Engine richens after refueling
I keep having the same problem for a while now. Engine runs fine but i keep getting a rich setting just after refueling and needs about 30m into the track to clean up. The same thing happens to my brothers engine.
I drive a Sirio Kanai EVO 4 and my brother RB WS9.
Anyone knows what causes this ''problem''?
Sometimes it might flame out...unless i keep blipping the throttle for the first 10m and then take it easy for the next 20-30m and try clearing it up at the jumps.
vti-chris is offline
Old 09-06-2009 | 08:45 AM
RevMaxx's Avatar
30m? how big the size of your tank?
RevMaxx is offline
Old 09-06-2009 | 08:51 AM
vti-chris's Avatar
Old 09-06-2009 | 08:56 AM
RevMaxx's Avatar
you mean for 1 full tank, you can run beyond 30 minutes?
RevMaxx is offline
Old 09-06-2009 | 09:06 AM
vti-chris's Avatar
Oh no...m=meters(metric here!!!)
Old 09-06-2009 | 09:12 AM
RevMaxx's Avatar
ahh... didn't think of that one..
its probably just your LSN being set too rich. when you pit and engine is at idle, it loads up fuel due to rich setting.
RevMaxx is offline
Old 09-06-2009 | 10:17 AM
vti-chris's Avatar
Nope...can't be that. When refueling engine should lean a bit due to open lid. Besides engine takes off strong after idling for 10 sec. Engines are set right...maybe a bit rich on top end for the 30 minute final and 100F plus weather.
Old 09-06-2009 | 12:18 PM
could be 2 things:
1) to rich on the LSN, if you let it idle with refuling the engine runs full
2) a leak in the fuelcap of the tank.
Roelof is offline
Old 09-06-2009 | 02:59 PM
wingracer's Avatar
That slightly rich on the top you mentioned can do it too. Don't let the tank being open fool you, they can still load up. Also, too cold a plug can do it, especially if the motor is running fairly cool head temps.
wingracer is offline
Old 09-06-2009 | 03:28 PM
Most complain about flame-outs while getting
back out on the track. Running a little rich for
the first ninety feet after a fuel top-off is better
than a flame-out problem. I know it's annoying
but I'd trade that for one that coughs,farts and
stalls any day.
rageworks is offline
Old 09-06-2009 | 03:29 PM
Try a exhaust cooler. If it were my car I would just lean it a little.
sheeley is offline
Old 09-06-2009 | 03:31 PM
How long does it run rich after fueling?
sheeley is offline
Old 09-06-2009 | 03:44 PM
n/m, I see 30 meters
sheeley is offline
Old 09-06-2009 | 07:48 PM
lastsun's Avatar
it could be your pressure tube between the pipe to fuel tank be too slow. that is why after u refuel, the pressure be come too high thus pumping more fuel into the carbe....
wat is your current length your tube now??? is it at least 15cm long ???
lastsun is offline
Old 09-06-2009 | 10:03 PM
vti-chris's Avatar
yes that's 15cm, but i've read somewhere something about 25-30cm.
