Engine richens after refueling
I keep having the same problem for a while now. Engine runs fine but i keep getting a rich setting just after refueling and needs about 30m into the track to clean up. The same thing happens to my brothers engine.
I drive a Sirio Kanai EVO 4 and my brother RB WS9. Anyone knows what causes this ''problem''? Sometimes it might flame out...unless i keep blipping the throttle for the first 10m and then take it easy for the next 20-30m and try clearing it up at the jumps. |
Originally Posted by vti-chris
(Post 6307692)
(Post 6308106)
Oh no...m=meters(metric here!!!)
(Post 6308145)
its probably just your LSN being set too rich. when you pit and engine is at idle, it loads up fuel due to rich setting. |
Nope...can't be that. When refueling engine should lean a bit due to open lid. Besides engine takes off strong after idling for 10 sec. Engines are set right...maybe a bit rich on top end for the 30 minute final and 100F plus weather.
could be 2 things:
1) to rich on the LSN, if you let it idle with refuling the engine runs full 2) a leak in the fuelcap of the tank. |
That slightly rich on the top you mentioned can do it too. Don't let the tank being open fool you, they can still load up. Also, too cold a plug can do it, especially if the motor is running fairly cool head temps.
Most complain about flame-outs while getting
back out on the track. Running a little rich for the first ninety feet after a fuel top-off is better than a flame-out problem. I know it's annoying but I'd trade that for one that coughs,farts and stalls any day. |
Try a exhaust cooler. If it were my car I would just lean it a little.
How long does it run rich after fueling?
Originally Posted by sheeley
(Post 6309100)
it could be your pressure tube between the pipe to fuel tank be too slow. that is why after u refuel, the pressure be come too high thus pumping more fuel into the carbe....:tire:
wat is your current length your tube now??? is it at least 15cm long ??? |
yes that's 15cm, but i've read somewhere something about 25-30cm.
| All times are GMT -7. It is currently 07:08 PM. |
