Go-Tech Engines Thread
#8161
Zonda thats the perfect pipe for the 5 port from Dynamite. I used the same 1. If you have any questions just come here and anyone will help you out. The 5 port is awesome for buggy or truggy. Buggy I suggest a small carb restricter carbon shoes w/1.0 springs, truggy stock restricter or a tad smaller alum shoes w/1.1 springs.
#8162
Rkess I am sure the 3's will be in shortly after because alot of people like the 3 here I guess, I do. He with the 5.5's had mostly 3 ports. I had some racefactor stickers but just did 2 new bodies and used them all up or I would have given you some I will see if i can get a few my next order. I got Racefactor stickers on my E-buggy body LOL.
#8163
Hi, sorry to hijack the thread, but I've just picked up a used Go 5 port
(still needs more runing in) I've read on here that the dynamite pipes work good with these engines.
could you tell me if this one is ok.
http://www.modelsport.co.uk/index.ph...n&ItemID=32904
Also would the tuning bible at the top of this page be a good reference for tuning these mills.
Many thanks
Rob
(still needs more runing in) I've read on here that the dynamite pipes work good with these engines.could you tell me if this one is ok.
Many thanks
Rob
The tuning bible is very good, especially the section on idle gap and low speed needles being too rich. The GO's (most of them, and I'm assuming yours is fairly recent) have a long tapered low speed needle which tunes totally different to most other normal length needle carbs out there.
You have PM on tuning details. Also check out the Massive Mods Tech Tips page on the web site at -
http://www.massivemods.com.au/index....d100c746824203
Lots of good info there
#8164
Malik, Grizz, thanks for the responce guys
I will be using the exact clutch setup you mentioned Malik Iwill be using the 1.0 springs for the buggy.
Grizz I dont no which Gen the 5 port is so I uploaded a pic of it.
thanks for the PM too cant wait to get this setup going in my buggy
#8165
Looks like either a gen 4 or maybe a 5. Does it have tribal graphix on top of the head? If so its a Gen 5 if it just says Go 5 port its a 4. Either way your okay they are pretty much the same mill. get a set of restricters they are a must with the 5 port in buggy. use the smallest 1 and you will still have more power than you need. And with the carbons and 1.0's if you find you want more of the line snap, trim alittle material off the shoes. I used to run alums but will never again in buggy just a waste of time and money if you ask me. Truggy yes they are needed. I mean to offent nobody thats just me. Bearings last way longer and I can go 4 race days easy on a set of $8 shoes and $1.29 springs.
#8166
#8167
Rex
#8168
Yeah - clutch shoes and springs all come down to the track condition and surface you race on really. So everyone has differing ideas and views, which all work fine for their own track and driving style.
Over winter here our tracks have been super grippy (when they haven't been under water
). I run three X-Ray lightened 1.71 alloy shoes and 1.1 springs in my buggy, with both my 7 port and modded 5 port, no problems. Gets out of the corners real good
, but under control. No way I would be running this on a loose and dusty track though.Normal summer conditions would be 2 x standard weight VP Pro Alloy shoes and 1 x Carbon shoe with 1.0 springs in the 5 port, and the same shoes but always 1.1 springs in the 7 port. Do some testing and see what works best for you
#8169
The only changes i have been making is wether I use the trimmed shoes for tracks with short run ups, when I need that extra snap. And for more technical tracks I use stock HB carbons, both set ups w/1.0's. I am about to give the answerrc carbons a try and they come with the full set of springa and I want to try 1 1.1 and 2 1.0's and 2 1.1's and 1 1.0. I also saw someone drilling 1-2 1mm holes in the shoe instead of trimming. I guess that would be more exact on the weight coming off. But when I trim I do 1 and use that for a template. I tried the carbon and alun mix before and had no liuck with it in my truggy last year with the PTM 5 port. Tore up bells and the carbon shoe didnt last half the time of the alum. But when I did use alums I used the Mugens both the LW and regular versions. Lots of guys have been loving the Dynamite long lifes at my local track and seem to last pretty good but I dont need all that snap. I would give them a try though.
#8170
The carbon shoe won't wear as long as the alloys in a mixed set up, it's not meant to. I would think you would wear through 2 or 3 carbon shoes per set of alloys maybe ?
Torn up clutch bell
what happened there ??? Shouldn't have been anything to do with the shoes I wouldn't have thought. Unless you didn't check them often enough, and the spring on the worn carbon shoe started eating away at the bell and ultimately toasted it ?? That would be a bit naughty Mr Malik
Torn up clutch bell
#8171
Just Picked up a GOTECH .21 3port
i ordered it with the pull start but they did not have them in stock.
what parts would i need to convert one without the backplate to pull start the
the parts are weird and im confused.
help would be greatly appreciated.....ty
#8172
For the price of a pull start kit (if one is available for the motor you have) you could buy a reasonable new, or second hand starter box (bump box). This is the best way by far to start your motors, especially when they are cold or you have flooded them. Once you have used a bump box, you will never go back to a pull start - ever
#8173
Just got the 5 port in the post this morning
looking at it I think its a Gen 4.
what glow plugs do you guys recomend ? will be using Byron Race 2500 Gen2 25% Fuel.
Cant wait to get this thing going....have to wait for my clutch system, pipe and a new starter box first though
looking at it I think its a Gen 4.what glow plugs do you guys recomend ? will be using Byron Race 2500 Gen2 25% Fuel.
#8174
Depending how many tanks it has had through it, it will most likely be very tight still. Make sure you heat it well with a hair dryer or paint stripping hot air gun before you start it. This makes it so much easier to start, and is a lot better for the engines internals too. You should heat the motor before you start it whenever possible. And always return it to BDC when you stop it.
Running 25% fuel you can run a medium or hot plug. Ideally, with 25% a medium plug is the most suited (say - O'Donell 97T or RB #6). The GO motors seem to be able to handle a hotter plug, so depending on ambient temps and conditions you may like to try a hot plug (say - O'Donnell 77T or RB #5), the OS P3 UltraHot plug is also used by a lot of the guys. I tend to run the medium plugs on 25% most of the time, and they work very well.
#8175
Your not too far away, are you going to race in the Mn Nitro series? www.mnnitroseries.com
Rex
2Likes
