Go-Tech Engines Thread
#8071
is the chassi milled out in the area the motor bolts down in , i would certainly look at differant mounts to try it will get expensive replacing motors all the time..
#8072
Yes correct , more nitro means hotter combustion temps however more nitro lets you run a tad richer which will cancel that out however ! if you run high nitro with incorrect shimming you will blow plugs and run hotter head temp with a cooler exhaust temp however if you run lower nitro with more shims you will get less torque but higher top end speed with hotter exhaust temps ! and a cooler head temp !
#8074
ok ill leave it and just lean the bottom abit so it at lest move a little
i also found the motor i was talking about
http://www.go-engine.com/in-products...15P-P820SG.htm
yeah its a bit differnt to my gen5 5 port but it will do for a spear.
http://carolinasrc.com/Webstore/Scri...idproduct=3886
the pic above is a gen3 or earlier, visiby the only difference is the cooling head.
Adrian
#8082
2Likes
