Like Tree3Likes
Tamiya M05 Pro
Old 06-14-2009 | 08:08 AM
  #151
subaru73's Avatar
Default m05
from tamiya usa
Tamiya is proud to introduce the release of a new chassis to the very popular M Chassis range, the M-05 PRO chassis kit. The new chassis layout features new servo, receiver,and ESC positions for improved weight distribution and a lower center of gravity. Further-more, a 3-piece tie-rod steering linkage offers sharp cornering performance. This machine handles extremely well on straights and proves its worth with its excellent high-speed cornering ability. Body shells and numerous Option Parts for M-03 chassis machines canbe loaded onto this machine easily.
Full ball bearings.
Length: 299mm, Width: 165mm, Tread: 138mm.
Includes three chassis extension attachment allowing you to make either a short, middle, or long wheelbase chassis car. (Wheelbases: 210mm, 225mm, & 239mm.)
A number of high precision parts such as aluminum rear uprights, aluminum ball connectors, setting spacer, three kinds of springs, high-torque servo saver, and aluminum servo horn are included.
CVA Super Mini Dampers (clear) and TRF short damper springs (soft, medium, hard 2pcs each, white) are included.
Motor and body are not included.
ESC, 2-channel R/C system, battery pack & charger are separately required.
A wide variety of Option Parts are available to further customize your machine.
subaru73 is offline
Old 06-21-2009 | 08:32 PM
  #152
Phat-Boy's Avatar
Default M05 BEARING SIZE
IT LOOKS LIKE M05 IS USING 1150 X 12 AND 850 X 4 BEARINGS ONLY. NO MORE 1050 BEARINGS IN FRONT AND REAR UPRIGHT http://www.tamiyausa.com/product/item.php?product-id=54179 WHAT YOU GUYS THINK ON GOING LARGER SIZE BEARINGS ON UPRIGHT.
Phat-Boy is offline
Old 06-21-2009 | 10:31 PM
  #153
jonest's Avatar
Tamiya Japan is releasing the R/C Lineup Guide, M05 hop ups should be ready soon...
jonest is offline
Old 06-21-2009 | 10:37 PM
  #154
monkeyracing's Avatar
If the uprights they're using are being transferred directly from the M-03R, then they would have been 10x5. It seems they're maybe using the "other" M-03 upright size though.
This could be to simplify the process of purchasing bearings. It could also be that a larger bearing may be a little more efficient.
Is this for the M-05 only and not the PRO version?
Jim
monkeyracing is offline
Old 06-21-2009 | 11:03 PM
  #155
Phat-Boy's Avatar
Default m05
m05 aluminum front and rear uprights part numbers are#54177 and #54178. m03r aluminum part numbers are#49441 and#49442. m05 pro comes with aluminum uprights... i wish i can use m03 uprights on m05. i think 1150 bearing are too big for mini. even tc's not using 1150 bearings
Phat-Boy is offline
Old 06-22-2009 | 12:50 AM
  #156
caltek1's Avatar
MO5 Pro only comes with rear alloy uprights. Alloy front knuckles are not included in the kit and need to be purchased seperately.
Regards,
Calvin.
caltek1 is offline
Old 06-22-2009 | 01:55 AM
  #157
Chiefy 707's Avatar
Is this how the pro really comes? Me likey lots!
+ YouTube Video
Chiefy 707 is offline
Old 06-22-2009 | 02:11 AM
  #158
Phat-Boy's Avatar
nope! that is pro with hopups. read top /\
Phat-Boy is offline
Old 06-22-2009 | 02:21 AM
  #159
Skitee's Avatar
I think there are only 3 things it doesn't come with, the blue screws, the trf shocks and the front aluminum steering knuckles.
Skitee is offline
Old 06-22-2009 | 11:54 AM
  #160
Chiefy 707's Avatar
I just messaged the dood who posted it, Skitee's right. That would've been so sweet if it at least had the TRF shocks.
I still want one though!
Old 06-22-2009 | 12:34 PM
  #161
second that. get rid of that alloy hub and craptastic clear shocks and give me the trf ones...
redbones is offline
Old 06-22-2009 | 12:46 PM
  #162
Phat-Boy's Avatar
maybe next year m05r with trf shocks...
Phat-Boy is offline
Old 06-22-2009 | 01:08 PM
  #163
not going to wait till next year
redbones is offline
Old 06-24-2009 | 11:58 PM
  #164
Chiefy 707's Avatar
So is it for sure the release day is the 27th? I already paid for mine in full!
Old 06-25-2009 | 12:02 AM
  #165
Skitee's Avatar
They actually release them in Japan today 2009-06-25, so it could already be on it's way to you if you ordered it from Japan.
Skitee is offline
