IDM Products?
#527
I believe they are doing it with all their carbs now (onroad engines). I do have a pretty simple solution if you have problems getting the carb to close consitantly. I had constant problems with that and what I did was to replace the small set (grub) screw that holds the ball end onto the slide. I use a pan head screw instead. I use a rubber band on the ball end and a second rubber band around the pan head screw. What it does is even out the pressure on the slide so the slide doesn't bind. Now it closes consistantly.
#529
#530
Are they all modified or they just say modified? I ask because im looking at the ofna version because of price. Also the prices on the website are insane! I found them on winnerscirclerc but he is out on vacation and i would like to order it to race this weekend.
#536
Hi..anyone could let me know which pipe is the perfect matched for IDM .21 Evo3 eng?
and which eng is more preferable either IDM .21 Evo3 or Nova Flash?....thx.
#538
tommy
#540
Thanks for the advised, Tommy...anything regarding with the pipe that is perfectly matched with IDM .21 Evo3?
