Team Magic E4 Thread
#2102
#2108
Thats such a trick question... How big is the track? What speedo are you running? I'm on a 100x36 track and am using 6.2 final with a Fantom Ion... Timing at 10 degrees and max punch (8) on the LRP SPX. The Xenon gears work very nicely and are available in one tooth increments. 105 spur and 35 pinion.
#2110
Congratulation to Dave Ehrlich for a fine result at the RROC. Large field of World Class racers with factory back up. Missing the invite sort was how it went. But then Dave took the A main in big style.
Well done Dave, look forward to being your hazard back at TZ 1 and 2.
Jacko
Jacko
#2112
Which kit is for us carpet racers?
I want to try rubber tire carpet next year with a car made for it. Wolf Hobbies definitly has a lot of choices but you guys all seem to run on asphalt. Last year I tested rubber tire with an RDX with a 10.5 and did OK. I am far from a great racer, just an average club racer. So, of the six or so variants, which one should it be for 10.5, rubber tire, technical carpet track, club racing.
#2113
I finished 6th in the final A AT THE M3 on french national starting 4th in qualifying this week!!
i used
13.5 tpr stock spec and lipo ip 3800 35c
more picture here: http://teammagice4.blogspot.com/
i used
#2115
