Like Tree2Likes
Go-Tech Engines Thread
Old 05-07-2009 | 10:09 PM
  #6676
Originally Posted by MassiveMods
Hey James there are several , where are you from ?
Im in Texas, USA
racer6888 is offline
Old 05-07-2009 | 10:16 PM
  #6677
How did you run in the engine ?
Sounds like heat swell causing blow by ..
M
I heat cycled the engine to break it in.
Old 05-07-2009 | 10:24 PM
  #6678
MassiveMods's Avatar
The 086 is different to the 2047
I prefer the 086 personally . The 2047 makes more HP up top and is better for high speed runs. The 086 is a nice all rounder , but you can change that with longer or shorter headers.
Personally the 0801 and 2072 rock my world the most
M
MassiveMods is offline
Old 05-07-2009 | 11:17 PM
  #6679
Massive, do you have any insight / comments on the new Go turbo plugs? have you had a chance to run them yet?
infernotb is offline
Old 05-08-2009 | 04:15 AM
  #6680
Gizmatron's Avatar
Just fitted my new GO 2072 pipe..looks very nice indeed! naturally now I've fitted it the rain has returned..maybe it will just be a shower or two..
Gizmatron is offline
Old 05-08-2009 | 01:29 PM
  #6681
Default my little GO
i getting giddy. Cant wait tell i get my motor back from RACE FACTOR. Ive been placing 4- 5 in my qualifiers and if i make the main its been hell can i only get about 5 1/2 min of run time out of my mach 427. when i get the GO back ill be in front for sure. oh about the clutches i just had nightmare hell with them. i ditched the losi clutch and messed with a WErks THAT SUCK , BUT I THINK WITH TIME I COULD GET IT TO WORK I WAS JUST MISSING A WASHER. know i am working with a mugen and its great i actually can clear everything at 1/4 throttle instead of hammering the throttle, LIFE IS GOOD real good
leapinglizard is offline
Old 05-08-2009 | 01:47 PM
  #6682
The werks clutch is awesome but hard to use at 1st, but when you get it right its the bomb.
malik is offline
Old 05-08-2009 | 02:32 PM
  #6683
Default well if i could get some help
i would run it i think i was missing the washer that goes behind the flywheel. when i would thightn it down to flush it would be all the way tight no play when i made it loose the shoes melted lol help could make thing good. i got it at the track from one of the expert buggy guys it was maybe not all there
Old 05-08-2009 | 05:05 PM
  #6684
22Racer's Avatar
The Losi clutch is very good when setup properly.
Rex
22Racer is offline
Old 05-08-2009 | 05:13 PM
  #6685
Default the werks
i thought it would act like the slipper clutch on a 1/10 electric but who know .i went with the mugen three shoe fly wheel with max life aluminum shoes and 1.1 springs Robinson racing bell. and i can drive know its amazing
Old 05-09-2009 | 05:50 PM
  #6686
bigmatt's Avatar
has any one had this happen to them? one of the cooling rings in the center of the cooling head broke off. whats strange about it is it broke off perfectly round. all around the head in one exact piece. I will post a pic later. it broke away from the cylinder head completely around and is still sitting there. there are no nic's on the outside of the cooling fin where I thought some thing hit it causing it to break.
bigmatt is offline
Old 05-09-2009 | 05:51 PM
  #6687
bigmatt's Avatar
has any one had this happen to them? one of the cooling rings in the center of the cooling head broke off. whats strange about it is it broke off perfectly round. all around the head in one exact piece. I will post a pic later. it broke away from the cylinder head completely around and is still sitting there. there are no nic's on the outside of the cooling fin where I thought some thing hit it causing it to break. by the way it is a go tec 5 port
bigmatt is offline
Old 05-09-2009 | 05:58 PM
  #6688
HaulinBass's Avatar
how tight is your body around the cooling head?
HaulinBass is offline
Old 05-09-2009 | 06:19 PM
  #6689
22Racer's Avatar
We broke a head fin like you said, the body was too tight around the head. On other brand motors I've broke the top fin off but never on a Go.
Rex
22Racer is offline
Old 05-09-2009 | 06:34 PM
  #6690
slakr's Avatar
Hey Rex... sent you an E-mail.
-Tim
slakr is offline
