8T 2.0
Old 02-20-2009 | 03:18 AM
  #1081
Electrics are for people with limited intellectual abilities. Just plug and play.
A high post count could mean 2 things......you've been on here for a long time, or ......you have no life.
K.Copeland is offline
Old 02-20-2009 | 04:09 AM
  #1082
jldjlaudio's Avatar
And I run nitro and my buddy that has the Bl 8t has both so how the hell does that make any seance.. So what your saying is you have never had electric? And because someone is on here or online in general alot that means they have no life??? I guess if you say so !!
jldjlaudio is offline
Old 02-20-2009 | 04:22 AM
  #1083
jldjlaudio's Avatar
And I just mainly posted about the price of the truck, didnt ask or care to hear a stupid comment on it!! But now because ALOT of people like brushless that makes them more or less stupid LMFAO!! Comming from a guy who sells R/C equiptment... I've bought from you so I know what you sell!! unless you stole that name and I'm wrong!!
Old 02-20-2009 | 05:13 AM
  #1084
J-DUB's Avatar
Thumbs up
yes. they are a much tighter fit on the side to side play. we also took some of the runout out of the front bearing the injection mold left .005 to .006 run out and now there is about 2 to 3. i am doing spindles just for the simple fact of buying 1 size outer bearing and that even the front bearings were locking up not blown yet, but on there way out the door for sure. thanks again tix for the tip.
Originally Posted by TIX
nice work J-DUB
Did you keep the bearing .2mm proud of the hub. I found that of all the ones I have done over time the ones that sat proud .2mm worked the best. It takes up alittle bit of the play so there's alittle less pressure on the bearings
Hopefully Losi will pull there finger out and start making them as a hopup part. That way we won't have to spend so much time machining them up.
Anyone in the US be sure to contact J-DUB for this mid. If your in Australia and want it done I can get it done for you
J-DUB is offline
Old 02-20-2009 | 06:09 AM
  #1085
For some one with so many posts you should know your going to get a stupid comment if you ask for it or not.
LosiMadMan is offline
Old 02-20-2009 | 06:31 AM
  #1086
Integra's Avatar
Originally Posted by LosiMadMan
The arms are made from a different material, so thats why they have different #s. As far as the chassis you don't have to have the new arms, but you do HAVE to have the new mud guards and rear drive shaft. I would get the new servo tray and likage or make your own linkage.
since when do you HAVE to have the new dirt guards ? you can just shave the stock one....and FWIW you do Not Need to buy anything linkages related.....ive rigged up 3 1.0T linkages to work with the 2.0 parts no problem.
Integra is offline
Old 02-20-2009 | 06:52 AM
  #1087
I'm sorry I was under the impression that they were longer on the 2.0. Personally I would rather have the longer linkages. I feel it's better than making them fit.
Old 02-20-2009 | 07:16 AM
  #1088
JAMMINKRAZY's Avatar
+1. Unless you buy the 2.0 radio tray you don't need dirt guards or the linkage. If you want to put the 2.0 tray on all you have to do is cut a lil' out of the radio side dirt guard and get some longer linkage rods, or I'm sure you can make the stock ones reach.
JAMMINKRAZY is offline
Old 02-20-2009 | 08:33 AM
  #1089
Lars Johnson's Avatar
Pretty good 1st outing for the 8T 2.0 at the Nitro Challenge. After Qualifying:
1) Ryan Cavalieri - AE
2) Mike Truhe - Losi/GRP
3) Travis Amezcua - Hot Bodies
4) Adam Drake - Losi/GRP
5) Cody King - Kyosho
6) Ryan Maifield - AE
7) Ty Tessmann - Hot Bodies
8) Jared Tebo - Kyosho
9) Billy Fischer - Losi/Novarossi
10) Philip Atondo - Losi/Novarossi
11) Jesse Robbers - Hot Bodies
12) Martin Bayer - Losi/GRP
13) Yannik Agoin - Losi/Novarossi
6 of the top 13, and 10 in the top 26 (A & B mains). I know there are at least 5 in the Open Truggy A-Main also - not too shabby!
Lars Johnson is offline
Old 02-20-2009 | 09:26 AM
  #1090
jldjlaudio's Avatar
How the hell was my first post asking for any stupid comments.. Looks like your just another guy talking just to talk.. read everything before you comment... your only purpose here is to try to fuel the other guys fire with this... otherwise useless posts!!
Old 02-20-2009 | 09:47 AM
  #1091
Frank L's Avatar
Settle down Beavis. It's nap time again.
(useless post here)
Frank L is offline
Old 02-20-2009 | 09:51 AM
  #1092
(useless post here)
Your right your post is useless. So are all the rest of them applying to this subject by all parties. Enough with the bickering already.
Old 02-20-2009 | 09:53 AM
  #1093
rhino420
Guest
Posts: n/a
so to beat a dead horse..... its possible and cost effective to convert a 1.0 to a 2.0 ? i run brushless so i dont need the radio tray
Old 02-20-2009 | 09:57 AM
  #1094
Prolly not. You will spend ALOT to get everything to be 2.0 spec. There are just too many changes made to the truggy to be cost effective to convert it. You are just better off buying a 2.0. I mean they changed chassis, shock setup, arm length, wheel offset, all kinds of geometries, all driveshafts except the from center, etc. Really it is just too much to convert.
Old 02-20-2009 | 10:01 AM
  #1095
rhino420
Guest
Posts: n/a
yea i guess im a noob because i look over the website and the parts exploded pages and i see alot of the same part numbers but maybe its alot more then just that i just dont want to spend another 600 bucks for a truck im just being cheap i guess but they do looks sweet as hell !!
