Novarossi engines thread
#2956
Btw, Are pre runned engines also means already break in ?
#2958
#2960
has awsemone bottom end i run the medium header it also better on fuel than the 2630 also the rb 2604 is similer
#2961
#2963
haha i just worked this out when i was buying my Sct
the S is silicon ramp in the crank shaft
the C is Ceramic Rear Bearing
and the T is a tuned crankshaft
now if you get the Tuned version it has some modding done to the sleeve i believe.
there are different combinations if you look on the Novarossi website i think its the ST which has the silicon and the tuned crankshaft
the SC which has the Silicon and the Ceramic bearing
or the SCT which has the Silicon and the Ceramic and the Tuned crankshaft.
hope this helps
hope this helps
#2964
Quote from the Novarossi Website
"The engines with a Pre-Run treatment are ready to win your race with, they have ran 30 minutes on our in-house engine bench with more oil and less nitro in the fuel."
now i would say there 30min of running in isnt enough to go and hammer the engine, i believe it is just used to reduce the time it takes, cause i just put about a 1L of fuel through my 3SCT tuned and its still has heaps of pinch at TDC and it took over an hour to put 1L through it.
From what i can understand this 30min would be the time used to idle it so you can start running it round on a track on rich settings.
but that is what i am interpreting from there website.
Mitchell
#2966
hope this helps
hope this helps
The "S" stands for Special I believe, meaning the crankshaft is 11.9mm not 11.5mm like the CT. The Novarossi 12-SCT is the only Nova based engine which has a 11.9mm crankshaft. All the other new Nova based engines, RB R3 RC, JP Eagle, MAX XXL3 all have 11.5mm crankshafts.
Difference between the "T" and not "T"
"T":
http://www.novarossi.com/img/img_pro...x300/85607.jpg
Not "T":
http://www.novarossi.com/img/img_pro...x300/85606.jpg
#2970
(edit: i got the fins the wrong way around
the 2630 with a 7 fin header would be killer. but it depends on what your track is like
if it is small and twisty with a shortish straights i would say the 2630 with the 7 fin header
but if its long and flowing with long straights i would say the 2630 with a 5 fin header
Mitchell
)the 2630 with a 7 fin header would be killer. but it depends on what your track is like
Mitchell
195Likes
