Mugen MTX-3
#7291
Originally posted by Manticore
i am considering if i shold put MAX #1 or MAX #2 !!
#1 and #2
#7292
Originally posted by FAST1
#1 and #2
#1 and #2
#7293
Thanks for BLOW'N ME AWAY!!!
#7294
#7295
#7296
Originally posted by Corse-R
>190Ft of backstraight and a total track lenght of 897Ft (297 meters) is enough long? 200mm cars do it on 20 secs or little less. If answer is yes, bring it here and will test it and see how performs.
#7297
Originally posted by RClover
Corse-R, were you at European, Vila Real? that's a A class track with tyre killer track surface.. they did that on purpose?
On Europe are very common to see those kind of tracks.
Regarding Euros, couldn't went at final (weren't hotel rooms at a reasonable rate)... Next Euro is on Austria or Switzerland (much probably another killer track there (Lostallo is another killer track)
#7298
mtx3 abc's
Hello MTX-3 lovers!
Got an MTX-3 and was wondering how the A, B, C rear blocks works? Like how the car would react using each of them?
There are also A, B, C steering levers and would like your comments on how each piece differs from the other two.
Hope you guys can feed me in on these ABC's.
#7299
Re: mtx3 abc's
Originally posted by edgar
Hello MTX-3 lovers!
Hello MTX-3 lovers!
Frnt A-most ackermann....C-least ackermann...B... in btwn
Rear A lowest roll centre....C highest roll centre...B in bwtn...
the nearer the roll centre to the centre gravity the less roll the car has when negotiating bends n vice versa....hope it clears ur doubts
#7301
Re: rear anti squat
Originally posted by rcmike
VONES- IF SOMEONE RUNS ON A SMALL TRACK[LHS ON RUBBER TIRES] WITH A LOT OF TWISTIES,RUN BLOCKS C IN BACK AND PERSONAL PREFERENCE UP FRONT ON ACKERMAN?? DO I UNDERSTAND RIGHT THAT C BLOCKS IN REAR ARE HIGHEST OR POSITIVE ROLL CENTER ON THE CAR? THANKS
#7302
Re: rear anti squat
#7303
stock mtx3 rubber sealed bearings
replaced the kit bearings with the ceramic nitride bearings today. spent me 3 hours and it is a dirty job !!
the kit bearings were very dirty when i took them out. after a rub in a towel, the bearings look new and they are still very smooth. I havent broken any of the kit bearing but replaced them when changing the rear diff oil last time.
#7304
damn! ACER ceramic nitride bearings??
send me your stock bearings since you dont need them..!
thanks
thanks
#7305
translate please
vones
thanks, however i was hoping for descriptions or comments of how each piece work. like how does more ackerman differ with lesser ackerman. and how high roll center feels on track compared to lower roll center or why do we want to have more body roll compared to less body roll???
