Corally SP12X
Old 04-07-2008 | 06:33 PM
  #496
here's my 1st place 12x just before the New Zealand North islands
drivingpro is offline
Old 04-08-2008 | 01:59 AM
  #497
bs6ef's Avatar
Hey Drivingpro
could you post your setup you use for outdoor racing
cheers
steve
bs6ef is offline
Old 04-08-2008 | 07:56 AM
  #498
Yup, it'll be helpful to have some advice for bumpy low grip asphalt
ammo is offline
Old 04-09-2008 | 03:15 PM
  #499
sure. my car was on rails, CRC front end + corally diff = win!
Rear part of the car:
Motor:
I just love this new motor, the Reedy PT (mine is a 10x2), lacks down low torque which is great for pro12, and makes up for it with mid-end range torque. I lasted the last A main with it and my old battery pack only decided to take in 3300 charge
Gearing:
Was a medium sized track, I ran a 95 spur, with a 27 pinion.
Tyres:
I ran Pink corally rear tyres on the saturday qualifying. as the heat picked up I switched to some KAWADA rears which I had they just love the heat.
T-bar
Soft t-bar, with the corally spacer cut up into washers, and I didn't use the middle screw for the t-bar for more rear grip.
shock
I used the standard weight oil for the shock, but used a very soft spring to soften the rear even more.
side dampers
used soft corally side damper fluid
Front part of the car:
I'm using the CRC pro-strut front end
Tyres:
CRC pro cut Magenta fronts, work great
Camber:
1.5 degrees negative camber
Caster:
All 3 caster washers to the back
Dynamic Caster:
Use the 10 Degree block
Toe:
Slight toe out for a bit of corner entry aggression
Old 04-09-2008 | 04:03 PM
  #500
bs6ef's Avatar
Thanks drivingpro i'll give it a go
steve
bs6ef is offline
Old 04-09-2008 | 07:32 PM
  #501
Congrats, drivingpro! Well done.
Larry Brown is offline
Old 04-10-2008 | 12:58 PM
  #502
REZRCT's Avatar
"drivingpro's" Setup is awesome for outdoor asphalt. I use it as well, feels like the car is on railsl
REZRCT is offline
Old 04-10-2008 | 04:36 PM
  #503
bs6ef's Avatar
Do you guys use additive on your tires?
bs6ef is offline
Old 04-10-2008 | 07:40 PM
  #504
REZRCT's Avatar
Unfortunately we are not allowed to use tire additives in New Zealand.
REZRCT is offline
Old 04-22-2008 | 07:06 PM
  #505
Does anyone have an asphalt setup for the 12x on med. to med. high bite asphalt, with Paragon or other additive? Cool and hot track temps? Trying to get some info on what to start with at the U.S. Nationals.
Old 04-22-2008 | 08:06 PM
  #506
Here you'll have one!!
Arn0 is offline
Old 04-23-2008 | 05:25 AM
  #507
ArnO- Thanks for the link, I've never seen that site before. Nice resource. Unfortunately, there is no setup listed for higher bite asphalt using traction compound. The only asphalt setup listed is for NZ where they don't allow traction compound, and the track is rated as low bite.
Old 04-23-2008 | 09:31 AM
  #508
Budman's Avatar
This is the setup I've been using. Smooth med. to high traction.
Front:
springs 20 or 18 (start the day on 18's and change to 20's by the 3rd round)
split caster
10 deg blocks
crc extra heavy lub on king pins
1.5 camber
4 mm ride height
servo flat
Double pink tires
Rear:
1.6 T-bar
30 wt shock oil
green spring
1.5 droop
crc heavy lub on side dampers (white cap)
4mm ride height
Double Pink rears
This is a stock motor setup and works well. I will be testing more next week. Hope this helps.
Budman is offline
Old 04-23-2008 | 12:31 PM
  #509
Budman- Thanks! That's exactly what I'm looking for. Question about the 1.5mm droop- does that mean the main chassis is 1.5mm lower at the rear than the front? Or something else?
Old 04-23-2008 | 12:56 PM
  #510
Korey Harbke's Avatar
I think he means that the rear of the main chassis lifts up 1.5mm past ride height. So I think I'm going to paved nats too... Not sure I'll be running 1/12 though. Been workin on the sedan a lot lately
Korey Harbke is offline
