Old 01-21-2008, 05:51 AM   #346
Heckuva lineup, Paul. Looking forward to it, although I'll only be there Monday and Tuesday...gotta work. Sigh.
Larry Brown is offline   Reply With Quote
Old 01-21-2008, 07:52 AM   #347
Hey Paul,
What t-bar and shock settings are you liking on the 12x?
Old 01-21-2008, 11:48 AM   #348
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by Larry Brown View Post
Hey Paul,
I am using the Hotbodies shock with 40wt AE oil. For the Tbar, Robbie has some new ones coming out that I have been testing. He said they will be available at the snowbirds in his shop. I have some that I can give you when I get down there.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 01-21-2008, 03:17 PM   #349
I have posted this in the 1/12th thread also, but more help maybe found in here with the 12x .... anywho...
I've got a few questions....
There is this sweeper (in the pic) which comes off the main straight, and you carry alot of speed through this corner, But 3/4 of the way through the sweeper my car starts understeering and i have to button off the make it around the sweeper, whilst some other 12th drivers carry more speed through there.
pic of the sweeper:
we don't use tyre additive
Chassis: corally sp12x (corally spec, standard front)
What i've tried:
Soft and hard T-bars
Soft and hard fronts,(even the softest compound still 'pushes' / understeers mid corner on power.)
hard and soft side damper fluid
Soft and hard front springs
different shock fluids / tensions.
I'm using pink rears, but thinking of going slightly harder to see if i can get more front traction.
Or i'm actually thinking of putting some weights on the very front of my 12x front, as there seems to be alot of biased weight to the rear.
Any tips?
Also....
I'm still a bit clueless as to what levels you adjust the tweak screws on the tbar for what surfaces etc etc?
cheers for any help... there is always more to learn with 12th
drivingpro is offline   Reply With Quote
Old 01-21-2008, 03:54 PM   #350
Thanks, Paul. Hope Jeff can get some direct, though What center spring is working?
Old 01-21-2008, 04:14 PM   #351
protc3's Avatar
pic of the sweeper:
What i've tried:
Any tips?
Also....
Try shimming under the front of the shock
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-21-2008, 05:29 PM   #352
Trader Rating: 8 (90%+)
How much are you guys shimming under the front of the t-bar? I started Frechettes car off with .040 under and it seemed very balance.
Johnny Carey is offline   Reply With Quote
Old 01-21-2008, 06:10 PM   #353
chicky03's Avatar
I don't have anything under mine. I think it has enough steering with out it but we will see at the snowbirds.
I am using the Ae green spring.
Paul
Old 01-21-2008, 07:35 PM   #354
Jeff didn't have any spacer in Cleveland, and his car had plenty of steering.
Thanks, Paul. Jeff used the silver center spring with 30wt AE oil in Cleveland and O-rings under the 1.6mm T-bar to stiffen side to side. He said it did NOT need any more steering. Jaco 2pink front and yellow rear tires.
Old 01-21-2008, 09:56 PM   #355
Korey Harbke's Avatar
I've been testing the new tbar as well. Main reason I haven't posted my setup is I wasnt sure we could talk about them yet hahahaha. I'm still fiddling around with it though, I'll post a final setup later this week I'm thinkin.
Overall first impressions are AWESOME
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-22-2008, 12:38 AM   #356
Lokanas's Avatar
Default Spacers?
Hi,
What solutions are you guys using to keep rear track width correct while using jaco prisms?
I'm considering machining AE style rear axle spacers, but maybe there are some wheel hub kits or something?
Lokanas is offline   Reply With Quote
Old 01-22-2008, 12:41 AM   #357
Most are just using a bunch of CRC 7mm axle shims. They are the only onws I know of that make shims in the right dia for our axle.
-Korey
Old 01-22-2008, 12:44 AM   #358
Lokanas's Avatar
Default Spacers?
OK then... Seems like i'll have to machine my own..
No problems with pinion "reaching" spur gear?
Old 01-22-2008, 06:38 AM   #359
We use the Corally extended pinions with no problems.
Old 01-22-2008, 08:48 AM   #360
Yeah, Corally's diff/axle setup is a little different than others. Using those pinions that Larry suggested will solve the pinion issue.
-Korey
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
