Old 09-25-2009, 04:12 PM   #601
wingman2's Avatar
Hi mate, I used flanged axle bearings to get the width out to 171mm.
wingman2 is offline   Reply With Quote
Old 11-24-2009, 04:03 PM   #602
Company Representative
CorallyUSA's Avatar
Now available from Specialized RC is a LIPO Conversion for the Corally SP12X WC. The conversion comes complete with all necessary hardware and graphite to convert your SP12X WC to lipo setup. Some features include all optional tuning side springs, all aluminum inserts installed, recessed slot for tape, recessed section for battery. Utilizing extra stiff quasi-iso graphite for high bite carpet racing throughout.
CorallyUSA is offline   Reply With Quote
Old 11-24-2009, 04:39 PM   #603
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
got a chance to run this chassis on the spx wc/lipo chassis last weekend... car was very fast and easy to drive. i was running lilac front tires and yellow or orange rear tires from parma..
i used the hot bodies damper with the associated blue spring. 30 wt losi oil (might try 35 or 40 wt this wekend)
side springs i used blue... comes with the kit
side lube i used several lubes thru out the day. corally red lube, 20k and 10k mugen diff oil.. found that 15k would be a better choice.. talked to rob at corally and said to try the diff lube this coming weekend.. that is what some of the other guys have been using... front end same as i was running on the t-bar car....
i would like to thank brad johnson also for the help with this setup and help when i bug him... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 11-24-2009, 11:28 PM   #604
nice my pop's rc shop has one of these conversions, but what about this
http://www.corally.com/
its on the front page as of posting
e-team hobby: www.eteamhobbyplex.com
Fort Collins Colorado
Gorilla Boy Racing
mxzhonkey is offline   Reply With Quote
Old 11-25-2009, 10:29 PM   #605
oze
Just a quick question:
If you change the T bar from 2 mm to 1,6 mm, do you change the spacer between the T-bar and the motor pod? The piece I talk about is called Tbar Lower Spacer 1,6mm (74740). Do you make any other adjustment or do you only change the T bar and that is it?
oze is offline   Reply With Quote
Old 11-26-2009, 01:35 AM   #606
Send a message via MSN to PMSorber
Yes, you need the lower spacer and also spacers for your ball-joints (74738) or buy the low ball-joints 75291.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 11-26-2009, 07:14 AM   #607
oze
Two more questions:
Under what conditions would the thin T bar work better and when would you use the thick T bar?
What are the T bar pivot clips (74736) used for?
Old 11-27-2009, 07:53 AM   #608
Two more questions:
Thin T-Bar: Low - medium bite tracks and slow technical curves.
Thick T-Bar: Medium - high bite tracks and faster "sweepers".
The clips you mention replace the rubber O-rings.
@ConSult Trading
Old 11-27-2009, 09:25 AM   #609
oze
Thanks. Clear.
Old 11-29-2009, 12:58 PM   #610
oze
is there any way to adjust the rear ride height in 0,5 mm steps (instead of 1 mm)?
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
