Old 09-06-2008, 05:48 AM   #526
PizzaDude's Avatar
Originally Posted by Hugo View Post
Does ayone use the corally tyres?
If yes which ones works well? Gold, grey, pink, Dbl pink, purple?
Thanks in advance for your answers.
;D
For a base setup start with:
Front silver
Rear gold
This combo always has grip.
If it is a high traction track try silver rear as well.
PizzaDude is offline   Reply With Quote
Old 09-07-2008, 04:14 PM   #527
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Hey guys, I decided to sell my Corally SP12x WC car. Here is the link to the F/S thread
http://www.rctech.net/forum/r-c-item...2x-wc-kit.html
brians11 is offline   Reply With Quote
Old 09-07-2008, 06:00 PM   #528
noline's Avatar
Hey guy's I have a gearing question Im racing on a 50 X 25 carpet track with a 1.75 rear tire how should i gear a 17.5
noline is offline   Reply With Quote
Old 09-07-2008, 06:36 PM   #529
Trader Rating: 27 (100%+)
It will depend on what motor you are using.
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 09-07-2008, 06:46 PM   #530
noline's Avatar
Im running these motors
Novak 17.5
Speedpassion 17.5 new roar version
Hacker 17.5
Losi 17.5
Old 09-08-2008, 03:05 AM   #531
I know that Corally have tires on 38 US wheels.
Here are the compound they have.
I'd like to know the equivalent with Jaco or Parma or CRC tires
FRONT
Lilac
Magenta
Purple
Double Pink
REAR:
Magenta
Orange
Gold
Grey
Pink
Double pink
Thanks in advance
Hugo is offline   Reply With Quote
Old 09-08-2008, 06:56 AM   #532
Noline,
At Vegas, I ran a 74 Spur with a 53 pinion with the Speedpassion motor. The track was much arger than what your describing, so I would recommend using a 50/51 pinion if your going with the Speedpassion.
For the Novak/Hacker motors, I would start with a 40/80 combo and go from there.
Good Luck!
Steve Boice
Old 09-29-2008, 10:11 AM   #533
Hello,
I've a Corally 12X WC and Jaco prism tyres...my problem is that the wheel touch the spur.
With old style wheels (no offset) it's ok but prism wheels have a 3mm offset...can you tell me how i can do to fit the Prism wheels on my car.
Thanks in advance
Old 09-29-2008, 06:12 PM   #534
Hello,
Thanks in advance
We ran into this and fixed it by running a file on the inside edge of the rear wheel while spinning it on the tire truer. Only needed to take about 1/2 mm off, if that. It was mostly interference from the foam overhanging the wheel, not the wheel itself.
Larry Brown is offline   Reply With Quote
Old 09-30-2008, 01:11 AM   #535
Hello Larry,
Thanks for the help. I'll do that.
Do you have a good basic setup for carpet???
Hugo
Old 09-30-2008, 05:00 PM   #536
Hello Larry,
Hugo
Sure do, from page 16 of this thread:
These are the changes from Jeff's Snowbirds setup on page 14 of this thread:
Center shock: Silver spring and 30 wt. Assoc. silicone shock oil. (there were no bumps on this track. If this setup is too aggressive or doesn't handle bumps for you, go back to the olive (green) spring, 25 wt. oil, or both)
Dampner Lube: Corally blue. Same comment as center shock, go back to red if necessary.
Tires: No change, except 1.64 fronts and 1.74 rears. We tried 2pink front and rear, 2pink fronts with yellow rear, and lilac fronts/yellow rear. Lilac front/yellow rear was the best (all Jaco tires).
The bite was about medium, so I know these changes will be good with high bite. We'll try even more aggressive settings next time we race on high bite.
Old 10-13-2008, 10:15 AM   #537
Budman's Avatar
Trader Rating: 22 (100%+)
Where can I find a gear adapter so I can run PRS pinion gears.
Chris Cooper
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 10-13-2008, 10:22 AM   #538
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
Chris Cooper
http://www.niftech.com/catalog.php?mode=4000
JamesArluck is offline   Reply With Quote
Old 10-13-2008, 11:53 AM   #539
Budman's Avatar
Thanks so much!!!!!!!!
Old 10-16-2008, 08:44 AM   #540
Default Corally SP12X new user.Help needed
Just purchased a Corally SP12X with Associated front end.
It is built as per kit,front springs weight ??????. Fitted the RS front blocks so smaller tyres can be used.
Every thing else is as per kit, tpiece thick ,Any adjustments mods i should be doing.Set ups etc
Plan to run brushless,10.5 on carpet.
Any help appreciated
tellan is offline   Reply With Quote
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 10:13 AM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
