Like Tree18Likes
Xray NT1
Old 12-27-2007 | 09:20 AM
  #2281
Ivan Dickson's Avatar
Talking
Originally Posted by asw7576
Do you want to get shot ?
Ivan Dickson is offline
Old 12-27-2007 | 11:20 AM
  #2282
D-nicest's Avatar
Originally Posted by joebiii
Hi guys , just like to ask if anyone is using the " Xray NT1 Composite Front Holder For Personal Transponder" ? and if possible share some pics of it installed in the car, coz I have one and not sure how its attached ..
I don't use it but from what I see your supposed use the two screws from the radio tray that go into the steering servo holder and just put the transponder holder in between them and the tray. In this pic it's the screws that the transponder is not being held down by
D-nicest is offline
Old 12-28-2007 | 12:45 AM
  #2283
you mean this thing? http://www.redrc.net/2007/08/xray-nt...te-pt-bracket/
_cyclops_ is offline
Old 12-28-2007 | 01:14 AM
  #2284
advfuel's Avatar
Default Transponder holder
This is were I mounted my transponder holder.
advfuel is offline
Old 12-28-2007 | 01:30 AM
  #2285
Use these holes to mount your transponder. They are as far forward as you can get which is the best place to mount it. (yellow arrows at the front)
CDS70 is offline
Old 12-28-2007 | 01:36 AM
  #2286
joebiii's Avatar
Thanks for the help guys, now I know we're to put it ..
joebiii is offline
Old 12-28-2007 | 09:59 AM
  #2287
DS Motorsport's Avatar
i'm using a small lipo so i have the transponder below the tank, it's as low as possible and centered, and it's really close to the reciever so i could cut of a lot of wire which saves weight.
DS Motorsport is offline
Old 12-28-2007 | 10:02 AM
  #2288
advfuel, i see you use the KO 2413 low profile servo.
Did you ever had problems with it, mine was broken in 2 months and i want to find out if it was just a bad servo or it's just made too small and electronics aren't up to spec to use in nitro.
Old 12-28-2007 | 04:18 PM
  #2289
advfuel's Avatar
Default Servo
DS Motorsport, these 2 servos are still the orginals. They would be 6 months old, raced twice per month plus testing. They have taken a fair beating as our track is marked out with 50mm polly tube.
If the end point adjustment and servo saver is not to loose or tight all should be well. I would recommend the servo for throttle & steering.
Now I have written this,they will probably fail now
advfuel is offline
Old 12-28-2007 | 06:33 PM
  #2290
grub's Avatar
Smile
Originally Posted by grub
gidday
can anyone advice me how to get traction to the rear as after 20 minutes i have gone from 62.5 mm 40 shore foam rear tyres to 100 shore hard plastic and other guys still have plenty of tyre left, i have been told than my cars is consantly spinning out of the corners,, it did seem slow out of the corners but i throught it was my clutch running 100k frount diff oil 60 rear with pink springs 33lb please help grub
ANYONE
grub is offline
  #2291
grub's Avatar
Smile
gidday
ANYONE
grub is offline
Old 12-28-2007 | 06:45 PM
  #2292
it looks like your rear package is not quite right 60,000 diff fluid and 33 lbs rear springs? that sure seems awefully stiff of a spring i would try some of the setups from the glc or toledo.
goop is offline
Old 12-28-2007 | 07:14 PM
  #2293
Michael_T's Avatar
ANYONE
What is the R/L tire wear like? What camber do you have set, and how are your tires wearing?
Michael_T is offline
Old 12-28-2007 | 09:09 PM
  #2294
Serpent-Dan's Avatar
you might want to go with a lighter rear diff oil
Serpent-Dan is offline
Old 12-28-2007 | 10:14 PM
  #2295
kanai2racer's Avatar
Has anyone broken an outdrive on the optional front lock oneway?
kanai2racer is offline
