Like Tree7Likes
Old 12-29-2007, 02:19 AM   #2296
grub's Avatar
Originally Posted by Novarossi View Post
What is the R/L tire wear like? What camber do you have set, and how are your tires wearing?
gidday R/R tyre wear a little more than the left as theres 6 left corners to 3 right
i have 3 deg camber l/r and 3.5 deg r/r camber
with 3 toe in on rear
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 12-29-2007, 02:24 AM   #2297
grub's Avatar
Originally Posted by Serpent-Dan View Post
you might want to go with a lighter rear diff oil
gidday serpent dan
i did think that i only tryed 10,000 for 0ne race
didnt take any notice as i broke rear belt that race
so i blamed the diff oil and went to 60,000
Old 12-29-2007, 03:31 AM   #2298
grub's Avatar
Hello all
what type of tyre wear should i be looking at after a five minute heat?
im currently getting to 1,28 mm over five.
is there a bench mark i should be aiming for?
Old 12-29-2007, 12:32 PM   #2299
Send a message via ICQ to _cyclops_
Originally Posted by kanai2racer View Post
Has anyone broken an outdrive on the optional front lock oneway?
Nope, how did ya do that? :P
_cyclops_ is offline   Reply With Quote
Old 12-29-2007, 03:26 PM   #2300
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Yep, twice! I don't think there is anything else u can do, other than not hit anything!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 12-29-2007, 04:37 PM   #2301
DS Motorsport's Avatar
Originally Posted by advfuel View Post
DS Motorsport, these 2 servos are still the orginals. They would be 6 months old, raced twice per month plus testing. They have taken a fair beating as our track is marked out with 50mm polly tube.
If the end point adjustment and servo saver is not to loose or tight all should be well. I would recommend the servo for throttle & steering.
Now I have written this,they will probably fail now
Ok thanks for your fast response, i've ordered a new one.
For steering i'll keep my sanwa wrx, for steering the feel of a sanwa servo is just the best, i think.
And i've knocked wood for you so they won't fail
DS Motorsport is offline   Reply With Quote
Old 12-29-2007, 06:13 PM   #2302
kanai2racer's Avatar
It just snapped, I'm thinking it was a mfg defect.
Sponsors:
Serpent America/Desoto Racing, Nitropro fuel, Pro-Line Racing, SS Hobbies & Speedway, R/C Addiction Products, paint by Bobby Smith
Freddy V.
kanai2racer is offline   Reply With Quote
Old 12-29-2007, 10:44 PM   #2303
c1 racin's Avatar
Send a message via ICQ to c1 racin Send a message via AIM to c1 racin Send a message via Yahoo to c1 racin
I've broken one also.
NeXusRacing.com
MurnanModified.com
MobileRCRacing.com
c1 racin is offline   Reply With Quote
Old 12-31-2007, 07:25 PM   #2304
Osiris 75's Avatar
Does anyone know what other Kyosho parts work on the NT1, other than uprights?
Chris Kemper
Old 01-01-2008, 01:46 AM   #2305
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Anyone tried these belts for the NT1?
http://search.ebay.com/_W0QQsassZapp6cxc
I want to stock up on spares, and these are about 50% the cost of geninue belts.
Here is the quote:
Brand new Front high torque direct replacement belt for your Xray NT1!!!
These are curvilinear direct placement for your Xray NT1, The shape of the teeth on these belts are elliptical rather then trapezoids (the stock belts are trapezoidal), here's why these belts are better than the stock ones:
* Stronger and more durable than the stock belts, these belts have more backings than the stock belts, yet they are softer, providing with less friction in the belt drive.
* Neoprene construction allows high flexibility in extremely high environments
* Elliptical teeth gives better "bite" between the gears due to deeper engagements
* Decreases slippage between pulleys.
* These belts carry 120% to 200% more load from trapezoidal belts.
* Please refer to diagram below for illustrations on elliptical teeth belts.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 01-01-2008, 03:31 AM   #2306
advfuel's Avatar
Trader Rating: 29 (100%+)
Default Belts
Here is the quote:
Novarossi send grub a pm I know he has tried them. They are thicker than the Xray belt which is good & bad.
advfuel is offline   Reply With Quote
Old 01-01-2008, 06:24 AM   #2307
grub's Avatar
Here is the quote:
mate
i have been using them ,they seem to hold up better than the standed ones
there a bit thicker than the std belt but which help it you pick up a stone or rubble..there a little softer to the touch than the std ones
but dont overtighten the belt i did on the rear and had one snap and seperate ,but that thats the only problem ive had with these belts
a good ebayer to deal with also
hope this helps
Old 01-01-2008, 08:18 AM   #2308
lim
lim's Avatar
hello, some photos of my NT1 from Italy!
Car : Kyosho RRR Evo Capricorn Edition
Engine : Sirio Evo 4c
Muffler : Sirio 2611
Radio : Ko Propo Helios EX10
Servos : Ko Propo 2413
Tyre : Capricorn / Matrix
Fuel : Capricorn Master Fuel 16%
www.capricornrc.com ... the best for RC!
lim is offline   Reply With Quote
Old 01-01-2008, 08:26 AM   #2309
asw7576's Avatar
Wow, cool endbell !! Who made it ?
Old 01-01-2008, 08:31 AM   #2310
lim
lim's Avatar
this endbell is made by Sirio, I use Sirio clutch. It's made for RRR, but it fit well also on NT1...
