Futaba 3VCS
#32
spektrum will fit, but why bother whenthe futaba 2.4ghz spread spectrum system is better faster and is black.
i found the spektrum to have a little lag, the futaba system is awesome..little more expensive but worth it in my opinion
#33
yeah, i think the futaba 2.4 GHz should be faster and better cause it's specially made by futaba for futaba transmitter.
However, in this part of the world , such good stuff is not yet here. Moreover, if it's here, the price is going to be far higher than what you guys are paying.
As for my spektrum, I have 2 transmitter module and 5 receivers. Upgrading to futaba would also mean i need to buy 4 more receivers to fit all my car line up.
#34
I wanted a stick radio but why is this thing $150 higher than most top of the line pistol radios? Are there any other good choices for a stick radio out there? Are there that many more features over the pistol grips to warrant the price? Don't mind spending the cash if it is worth it.
#35
From: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
http://www.precisionrc.com/nv/car/pr...oduct_id=53496
#37
http://www.precisionrc.com/nv/car/pr...oduct_id=53203
#38
anyone know if its possible to
rotate the Left hand side of the stick so it works horizonally like this - (to controll the steering)
rotate the Right Hand side stick so it goes verticall like this | (to control the throttle)
thanks
thanks
#41
Magm,
The Fasst is the same for the stick and wheel TXs. You use the same RXs for both.
You can change modes for the sticks but you have to open the case and swap the gimbals side to side. Opening your case means, presto! no warranty. Sorry
