Futaba 3VCS
Old 03-24-2007 | 03:23 AM
  #31
sosidge's Avatar
Pretty sure that would be the right Spektrum module, the 3VCS and 3PK are more or less identical.
sosidge is offline
Old 03-24-2007 | 05:53 AM
  #32
ooliganRC's Avatar
spektrum will fit, but why bother whenthe futaba 2.4ghz spread spectrum system is better faster and is black.
i found the spektrum to have a little lag, the futaba system is awesome..little more expensive but worth it in my opinion
ooliganRC is offline
Old 03-24-2007 | 06:47 AM
  #33
yeah, i think the futaba 2.4 GHz should be faster and better cause it's specially made by futaba for futaba transmitter.
However, in this part of the world , such good stuff is not yet here. Moreover, if it's here, the price is going to be far higher than what you guys are paying.
As for my spektrum, I have 2 transmitter module and 5 receivers. Upgrading to futaba would also mean i need to buy 4 more receivers to fit all my car line up.
azmio is offline
Old 10-25-2007 | 08:10 AM
  #34
I wanted a stick radio but why is this thing $150 higher than most top of the line pistol radios? Are there any other good choices for a stick radio out there? Are there that many more features over the pistol grips to warrant the price? Don't mind spending the cash if it is worth it.
TheIceman is offline
Old 10-25-2007 | 10:22 AM
  #35
Funkymojo's Avatar
Super Moderator
From: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
The Futaba 3VCS is a great stick tx, but the functions are pretty similar to the older Futaba 3PJS and not the 3PK. Settings can be tricky at times, the menu is definately not the best. If you're looking for a good and easy to set stick tx, try out the new Sanwa/Airtronics Exzes Plus. The quality is really good, and it is so easy to set it up, it works just like the Sanwa/Airtronics M11. It's got the best price too, compared to the latest stick tx from Futaba and Ko Propo. Check out the link below for more info....
http://www.precisionrc.com/nv/car/pr...oduct_id=53496
Funkymojo is offline
Old 10-25-2007 | 04:42 PM
  #36
Thanks for the info Funky, is the spektrum module and reciever for the m11 compatible with Sanwa/Airtronics Exzes Plus?
Old 10-25-2007 | 10:01 PM
  #37
Funkymojo's Avatar
Super Moderator
Yes it is buddy or you can even use the Sanwa/Airtronics DSSS 2.4GHz Spread Spektrum module and receiver. Check it out...Cheers
http://www.precisionrc.com/nv/car/pr...oduct_id=53203
Old 10-30-2007 | 09:00 PM
  #38
magm20001's Avatar
anyone know if its possible to
rotate the Left hand side of the stick so it works horizonally like this - (to controll the steering)
rotate the Right Hand side stick so it goes verticall like this | (to control the throttle)
thanks
magm20001 is offline
Old 10-30-2007 | 11:14 PM
  #39
FrankW's Avatar
Doubtful, but I'm sure you could switch the sticks.
-Frank
FrankW is offline
Old 10-31-2007 | 06:12 AM
  #40
magm20001's Avatar
anyone know if the Fasst TX for the 3VCS is the same as the 3pk?
please only answer if u 100% know.
Old 10-31-2007 | 08:31 AM
  #41
Rick Vessell's Avatar
Magm,
The Fasst is the same for the stick and wheel TXs. You use the same RXs for both.
You can change modes for the sticks but you have to open the case and swap the gimbals side to side. Opening your case means, presto! no warranty. Sorry
Rick Vessell is offline
