Futaba 3VCS
Old 04-13-2006 | 06:52 PM
  #16
Hi
Can I rotate the 2 stick's travel axis or adjust stick's height to suit my finger's movements same as the Sanwa super exzes?
G2B Anthony is offline
Old 04-14-2006 | 05:02 PM
  #17
FrankW's Avatar
Yes you can.
FrankW is offline
Old 04-16-2006 | 09:01 AM
  #18
FrankW
Thanks again
Old 11-23-2006 | 01:29 AM
  #19
Hi,
What Makes the Futaba 3VCS either HRS or PCM. Is it the module and receiver or is it something more 'internal'?
That being said, If I Purchase a 3VCS HRS could I use the non HRS spektrum system on it??
Thanks for any clarifications..
CRiXman is offline
Old 11-23-2006 | 01:53 AM
  #20
Alos will this spektrum system: SPM1014 fit in:
1. 3VC Super HR
And/or
2. 3VC Super PCM
Thanks!!
CRiXman is offline
Old 11-23-2006 | 03:51 AM
  #21
Funkymojo's Avatar
Super Moderator
From: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
1. 3VC Super HR
And/or
2. 3VC Super PCM
Thanks!!
Hi buddy..i think if you're using the 3VCS HRS..it's best to get the Spektrum HRS for it...you could use the normal Spektrum but there will not be a HRS function...i could be wrong though...
Funkymojo is offline
Old 11-23-2006 | 04:51 AM
  #22
razzor's Avatar
The 3VC is now available with 2.4 ghz ,so dont even bother with pcm or hrs.
http://www.nitro-models.co.uk/produc...580634e49cca98
razzor is online now
Old 11-23-2006 | 05:09 AM
  #23
Thanks to both responses..
the reason I am enquiring about this is because I have a spektrum 3500 micro receiver, which is not compatible with the spektrum HRS unit... So my question remains..
Will this spektrum system: SPM1014 fit in both the:
1. 3VC Super HR
And
2. 3VC Super PCM
CRiXman is offline
Old 11-23-2006 | 09:10 AM
  #24
Hi There,
I recently got this transmitter. It's a great radio!!! The way you switch between the modes is in the software. Basically you select either PPM, PCM or HRS and then turn the transmitter off and on for the setting to take effect.
Hope this helps.
jgee888 is offline
Old 11-23-2006 | 12:11 PM
  #25
hi, anyone knows any of the united state lhs/online store carry it yet? thanks
Engtat
EngTat is offline
Old 11-23-2006 | 12:16 PM
  #26
Funkymojo's Avatar
Super Moderator
You can try Rc Mushroom..i've gotten lots of stuff from them..fast shipping and good prices...check out the link
http://rc-mushroom.com/index.php?cPath=63
Old 11-23-2006 | 01:52 PM
  #27
Thumbs up
Originally Posted by jgee888
Hi There,
Hope this helps.
This is the feedback I needed!
CRiXman is offline
Old 12-13-2006 | 11:00 PM
  #28
Hi,
Will the Spektrum 2.4ghz system work with the Futaba 3VCS transmitter(40 mhz) set, if so which Spektrum do i need to get for it?
Thanks,
Everreadyrich
everreadyrich is offline
Old 02-17-2007 | 07:48 AM
  #29
http://www.academy.co.kr/ssForum/attach/3VCS.pdf
here ya go, 3VCS manual.
Thumbs is offline
Old 03-24-2007 | 01:22 AM
  #30
I wonder if it is possible to use 3VCS transmitter with Spektrum 3PK pro series transmitter module?
azmio is offline
