Novak ESC will not re-program
i wired up my remanufactured XBR ESC and insulated everything, but the ESC will not program for me now. according to the directions, doing the one-touch setup should restore the ESC to factory settings, but nothing happens. it's as if the ESC is already programmed, because it will not allow me to re-program it. with my transmitter on (Spektrum mind you, this may be a cause), i press the ESC setup button and hold it while i turn on the ESC. a solid green light and a blinking red LED immediately come on, and after about 2-3 seconds the green LED goes out and the red LED stays on. this is correct so far, but once i go to set the full throttle position according to the manual, the motor responds. typically, my novak ESCs do not respond until they are fully programmed. the ESC is not recognizing that i am trying to re-program it. what can i do?
use like a 3mm hex wrench to push the button down. its not the best button going around.
Are you using your XBR with a brushed or brushless motor...?
figure out which of the pins on the plug the switch closes when you push it, and just touch it with a screwdriver (shorting the 2 CORRECT terminals as if you were pushing the button)
