-   -   Novak ESC will not re-program (https://www.rctech.net/forum/radio-electronics/185797-novak-esc-will-not-re-program.html)
macnkitty2002 10-12-2007 10:44 PM
i wired up my remanufactured XBR ESC and insulated everything, but the ESC will not program for me now. according to the directions, doing the one-touch setup should restore the ESC to factory settings, but nothing happens. it's as if the ESC is already programmed, because it will not allow me to re-program it. with my transmitter on (Spektrum mind you, this may be a cause), i press the ESC setup button and hold it while i turn on the ESC. a solid green light and a blinking red LED immediately come on, and after about 2-3 seconds the green LED goes out and the red LED stays on. this is correct so far, but once i go to set the full throttle position according to the manual, the motor responds. typically, my novak ESCs do not respond until they are fully programmed. the ESC is not recognizing that i am trying to re-program it. what can i do?
macnkitty2002 10-13-2007 02:44 PM
any ideas?
macnkitty2002 10-14-2007 03:03 PM
none at all?
amain 10-14-2007 03:58 PM
1 Attachment(s)
try that
amain 10-14-2007 04:00 PM
it could also be that the button isnt touching the board on the esc. it happens to some novak esc.
macnkitty2002 10-14-2007 05:17 PM
thanks amain, but that's the problem i'm having. it's as if the button does not work.
magm20001 10-14-2007 05:22 PM
use like a 3mm hex wrench to push the button down. its not the best button going around.
macnkitty2002 10-14-2007 06:10 PM
i've tried that. it's pushed down plenty, and the other novak ESCs i have used did hot have this problem. maybe the factory did not clean the contacts when the remanufactured it.
Ashley Cobb 10-15-2007 08:41 PM
figure out which of the pins on the plug the switch closes when you push it, and just touch it with a screwdriver (shorting the 2 CORRECT terminals as if you were pushing the button)
Steve Weiss 10-15-2007 09:07 PM
Are you using your XBR with a brushed or brushless motor...?
macnkitty2002 10-16-2007 01:29 PM
brushed.
that's probably a good way to void the warranty!:lol::nod::rolleyes:
