Curious Futaba S9451 Servo Issue >
Old 04-29-2007, 10:48 AM
sosidge's Avatar
Default Curious Futaba S9451 Servo Issue
During today's racing I had a weird problem with my servo that I have never experienced before and wonder if anyone else has.
It's a Futaba S9451, only used at a few race meetings, so a high quality metal-geared digital servo, partnered with a Futaba PPM receiver, Futaba 3VC tx and a Keyence speedo, in a TA-05R.
As I came around a sweeper the servo did not come back to centre. There may have been very slight contact with the track markers as I came around, not enough to crash the car though.
Obviously I am parked up by the side, assuming that the servo saver had jumped on the servo as the servo was still moving fine, just offset.
Got back to the pit, switched off the car and transmitter, had a look at the car, mechanically it all seemed fine.
Switched the car and tx back on and the servo returned to the correct centre with correct travel again, and it was perfect for the last race of the day with no adjustments at all.
Any thoughts?
Seems like the servo temporarily "forgot" its correct centre, but I have no idea what would have caused it, so I am a bit worried that it might happen again.
sosidge is offline
Old 04-29-2007, 11:21 AM
ff01's Avatar
WOW
exact the same thing happend whit my servo today......but i run Hitec.
what can it be ?
//ff01
ff01 is offline
Old 04-29-2007, 11:29 AM
Korey Harbke's Avatar
I know this may seem kinda dumb... but check the gears. The futaba 9451 has one plastic gear in it. I know it came back to normal... but I would still check it to make sure.
Korey Harbke is offline
Old 04-29-2007, 05:25 PM
SammyZ's Avatar
Trader Rating: 138 (100%+)
Wow! I just bought S9451 and there is a palstic gear in it? Wtf? why?
SammyZ is offline
Old 04-29-2007, 07:49 PM
A lot of metal gear servos aren't entirly metal gear. Just look at the new high end ko propo servos. They usually have one plastic gear. Some companies have all metal gears though.
-Korey
Old 04-29-2007, 09:08 PM
R/C Tech Elite Member
JayL's Avatar
probably a bad tooth..
the one non-metal gear is to stop the circuit..all metal gear train will cause glitching...
some of the new KO's have a hybrid gear, stronger than plastic but non-conductive
JayL is offline
Old 04-30-2007, 06:04 AM
Rick Vessell's Avatar
Sosidge,
Sounds like a bad tooth on the plastic gear. I've had the same thing happen and it's been the plastic gear. Like Jay said, an all metal geartrain can cause glitching and you can blow out servo motors if you don't have a built in failure point.
Socko
Rick Vessell is offline
Old 04-30-2007, 08:36 AM
sosidge's Avatar
Had a good check of the gears, all seems well, hoping it was just "one of those things" and won't happen again.
sosidge is offline
Old 05-25-2007, 07:43 AM
sosidge's Avatar
TTT see TA05 thread for more on this issue.
sosidge is offline
Old 05-25-2007, 11:25 AM
94_snake's Avatar
One thing for you to check on... I had something similar happen to me running a 9550. As it turned out, the screws that were holding the plate on the steering system, were binding with the chassis. It would stick during the race, when I brought it back to the pits, it would seem fine. I replaced the countersunk with button head, and dremmeled down the chassis a little, and never had a problem with it after that..
So it may not be the servo problem at all, just a binding issue. Check that out and let us know if it worked...
94_snake is offline
Old 10-09-2007, 06:30 AM
PeteB's Avatar
I had a similar issue with a 9541 and upon investigation it was the plastic gear that was broken.
Does anyone know if I can get a replacement plastic gear. It seems kinda pricey to have to buy all the gears (AU$75 = US$60) when all I need is one tiny little plastic gear...
are there any others that will fit??
Pete
PeteB is offline
Old 10-09-2007, 08:22 AM
rtypec's Avatar
I think the plastic gear set from the S9151 and S9252 contain the plastic gear your looking for and cost a fraction of the price. I watoozied my S9451 this weekend and ordered some S9252 gear sets to repair the servo with. I should know for sure sometime next week.
rtypec is offline
Old 10-09-2007, 09:32 AM
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
this also happened to me using the same servo..problem is the servo horn. maybe the grooves/teeth inside it are already stripped. thus, making it not go back to center.
|JayFlores|2 is offline
Old 10-16-2007, 04:23 AM
I have a friend who this has happened too. He says these servos never go back to center after a bad crash.
samstheman2 is offline
Old 10-16-2007, 03:01 PM
kevinmajor's Avatar
Think of that plastic gear as a BLOW OUT GEAR. I'm pretty sure Futaba designed it that way so if you whack a barrier or something the gear will strip before you blow out the entire gear train or the servo motor. You can get a five or six pack of just the plastic gear for like 7 bucks.
kevinmajor is offline
