Like Tree2Likes
Go-Tech Engines Thread
Old 04-11-2019 | 08:50 AM
  #15121
frewster's Avatar
Yes! Thank you! What an odd size. I hope my engine wasn't damaged from running lean after the carb came loose.
frewster is offline
Old 10-25-2020 | 09:47 AM
  #15122
hey all - -Ive been out of the hobby for a few years and Im a bit foggy on some of this.... My son in law and I both have Tamiya TRF 801xt kits with Go-tech .23 engines. He is trying to start hios and the bump box wont seem to reach the flywheel. Its an OFNA, not sure if it is for a smaller car or what not. But is there a conversion kit for these to go to pull or bump start?
cesspool is offline
Old 10-25-2020 | 10:16 AM
  #15123
Team_Orange's Avatar
1. Buy a new rubber wheel for starter box
2.Shim the motor and wheel assembly in the starter box so the wheel sits higher.
I have the protek rc starter box and it was known to have issues like you are having whether buggy or truggy. The fix is what i stated above by shimming and problem solved. I used 3/16”aluminum flat bar to raise the wheel/motor assembly upwards.Hope this helps
Team_Orange is offline
Old 10-26-2020 | 04:34 AM
  #15124
Thanks! To clarify, this is the only option isnt it? Unless i swap engines?
cesspool is offline
Old 10-26-2020 | 04:49 AM
  #15125
Yes unless you go to a pull start engine this is your option
Old 07-25-2021 | 12:44 AM
  #15126
all sorted
heated up motor again and sleeve fell out.
Hi all
Need assistance
removed the carb from my B21 and the outer sleeve from carb broke off and it’s still in motor.
anyone know how to remove.
it’s stuck.
tried heating up motor.
stefana is offline
Old 07-27-2021 | 09:22 AM
  #15127
Blaster1's Avatar
Originally Posted by stefana
all sorted
Hi all
Need assistance
it’s stuck.
remove pinch bolts, heat up the block, carefully take a flat head, and press around the inner part of the sleeve and it should start to rotate, apply an upward pressure when turning the sleeve and work it up and out. Not sure where youre located, if you need help send it to me.
Blaster1 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
