Like Tree1Likes
JL Racing .12
Old 04-06-2007 | 11:14 AM
  #211
Hey guys, I just picked up the red dot through my lhs. I am a bit concerned though. It appears the sleeve does not sink even with the top part of the engine.It appears at least 1/2 of the rim of the sleeve sticks out and you can see it between the top of the engine and the head. Is this normal for the engine? I do not want to try and force it down. Thanks for your help
CHUCKMANDO is offline
Old 04-06-2007 | 11:43 AM
  #212
Artificial-I's Avatar
Ive seen some motors do this. Its apparently normal. I dont like it though , but just as long as dirt and such doesnt get down around the sleeve thats when I dont like it.
Also what temps are these motors pulling when tuned. Just so I got an idea?
Artificial-I is offline
Old 04-06-2007 | 11:49 AM
  #213
C Verano's Avatar
It is normal for the sleeve to be above the engine case.
C Verano is offline
Old 04-06-2007 | 12:05 PM
  #214
Ok great, Thanks Has anyone tried the rdlogics turbo II with the engine yet? Will the standard nova rossi plugs or os plugs work with this engine.
Old 04-06-2007 | 01:11 PM
  #215
Team Kamikaze's Avatar
Only PICCO plugs.
Team Kamikaze is offline
Old 04-06-2007 | 01:19 PM
  #216
bvalistic's Avatar
Originally Posted by Team Kamikaze
Only PICCO plugs.
what will happen if you use a novarossi turbo plug?? just curious
bvalistic is offline
Old 04-06-2007 | 01:57 PM
  #217
Only PICCO plugs.
Ok, guess I should have read more into the thread prior to purchase. I am on a learning curve, never ran picco before. Are there other brands like Ofna or Mega, plugs the same since they are picco based engines or do I have to look for strictly picco plug?
Old 04-06-2007 | 02:45 PM
  #218
No warranty
Dredd is offline
Old 04-06-2007 | 03:03 PM
  #219
quietstorm76's Avatar
It will run but it will tune erratic. In my experience it would go rich to lean then rich again.
quietstorm76 is offline
Old 04-06-2007 | 03:23 PM
  #220
It will also leak when using another plug other than PICCO plug.
Old 04-06-2007 | 03:25 PM
  #221
Ivan Dickson's Avatar
Thumbs up
VERY TRUE.
Ivan Dickson is offline
Old 04-06-2007 | 04:14 PM
  #222
I need help deciding between the jlr red dot and a os tz 5 port. If pipes, fuel, and setup etc....are all equal, how do these engines stack up against each other on acceleration and top speed. I can get either of these brand new for 170, just having trouble deciding which. I know the tz 5 port is outlaw, but the only track I run club races at allows anything that is .12. There are a few tz 3 and 5 ports at my track, along with some sirio's and novarossi. I would like to be the only one with the jlr red-dot at my track. What do you all think?
robzzz is offline
Old 04-06-2007 | 04:50 PM
  #223
HarKonnenD's Avatar
Sometimes it's good to be different. The results so far proves the JLR is not only an awesome motor, but it's priced a lot less than the other motors that are overpriced. Kudos to Picco for making a big comeback! I have two motors myself, but there is always room for more.
HarKonnenD is offline
Old 04-06-2007 | 05:26 PM
  #224
HarKonnenD's Avatar
Hey chuck, you think you're gonna make it down to Floyd this sun for warm ups? I think I'll be going there myself.
Old 04-06-2007 | 06:31 PM
  #225
Hi, not ready yet, car is all disassembled and will stat reconstruction tomorrow. I should be ready to go next week. I loved my CRF blazing fast, when working the fastest at the track. but had problems with humidity.
