Old 08-16-2008, 03:46 PM   #1711
I a not sure on the timing. Sam would know better he deals with the red dot I have just seen the IDM sets in the JL and also the Mega as well. I do not know how the JL ran but I watched the Mega and they ran better. Just some info remember you never know till you try!!!
xspower is offline   Reply With Quote
Old 08-16-2008, 06:56 PM   #1712
itchy b's Avatar
Seems that all the talk about, is the picco a good reliable motor have been answered!!!
Picco Wins World Championship!!!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-16-2008, 07:45 PM   #1713
Team Kamikaze's Avatar
You got that right, PICCO EDO modified engine is exactly the JL "TUNED" engine which Ielasi used to win the 1/10 IFMAR Touring car world championship.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-17-2008, 02:50 AM   #1714
stefan's Avatar
Send a message via AIM to stefan
Now that's even better than your statement in WC thread.
You REALLY thought hard how you could make any connection between your beloved JLR and the engine Daniele ran, huh.
Very creative, but unfortunately complete BS.
As I said in the other thread, Daniele is running Picco heatsinks in all his cars due to the sonsorship deal with Picco.
fact is that he is building his own engines for himself and trust me, they have not much in common with the JLR.
stefan is offline   Reply With Quote
Old 08-17-2008, 05:41 AM   #1715
Stefan is correct I spoke with Daniele myself and that is the reason if you look at the heatsink it is the picco head. All the internals other then the conrod are different. The JL tuned is not the same engine. It is close as the case is concerned but the internals crankshaft bore and other parts are different. That would be saying that the Max power 9 port is a 35+21. And that is not the case. Daniele won the works with the IDM not a JL EDO "Tuned".
Old 08-17-2008, 06:29 AM   #1716
rias5037's Avatar
ok, will try this IDM piston/sleeve on the JLR, just hope i does not loose power though.
rias5037 is offline   Reply With Quote
Old 08-17-2008, 07:34 AM   #1717
Yes, because the EDO is a better engine, that is why he uses the EDO and not his own IDM, just look at the pictures! it contains a thousand words!
p.s. If you have your own line then why not use it, in fact Alberto Picco called the owner of OFNA (Dave M.)and broke the news that the PICCO EDO modified engine won the worlds!
Old 08-17-2008, 07:42 AM   #1718
Originally Posted by Anders Myrberg View Post
Im pretty sure. If you look at Danieles collar, you will notice the "Edo" logo. Stands for Eduardo. But he sure used his own IDM Muffler.
And after the race, a hug from Eduardo himself. Im touched You dont get those without a reason, you know
One of the amazing things with Edo, except him being a Helluwa mech, is that his shirts NEVER get dirty. Never.
Nice pictures!
Old 08-17-2008, 03:16 PM   #1719
MHarrison's Avatar
WoW
MHarrison is offline   Reply With Quote
Old 08-17-2008, 08:54 PM   #1720
Suspended
Please do tell then how a shielded bearing that has no seal maintains crankcase vacuum without any leakage of air into the engine. And tell me how there is a leak between a inner race and the balls rotating at how many thousands of rpm? Oh and just for some more info the reason as I know this is how it is sealing is that I have spoken with the actual manufacture of bearings in fact a few of them as to confirm this years and years ago. I have done some work in the past with bearings. And if you are going to tell me that the clearance between the crankshaft and the crankcase is what is preventing this then you would have to mean that there would be less then .01mm clearance. The reason that this is happening then is why? And I am speaking of the front engine bearing leaking excess oil out. He is speaking between the inner and outer raceway not the bearing fit between the outer race of the bearing and the crankcase. Please let me know. I really do not like to even reply to these posts but I would like to hear how this is happening then. And you should truly not have to seal any part of the engine if the fits and clearances are correct that is what the o-rings are for.
Originally Posted by EdwardN View Post
I just suggested to do your homework and I am not a teacher.
Get the hydraulic dynamics book and find answer there. Then you will know how the sealing happened on systems like nitro engines.
I hope you had chance to talk to SKF or INA engineers, not sales rep.
Good luck!
the_geeky is offline   Reply With Quote
Old 08-17-2008, 09:37 PM   #1721
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Hey guys, Just got me a Picco jl...
What the factory settings for this thing? I cant find the info.
Thanks!!!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-17-2008, 10:22 PM   #1722
Thanks!!!
The factory setting is how it is when you got it out of the box, just install it in the car, put some fuel and fire it up, just remember that it is shimmed for 30% out of the box.
Old 08-17-2008, 10:28 PM   #1723
I bought it from my buddy. He used it for half a gallon (and I was the one driving it most of the time lol) , and then swapped to a RB. So its used, and I want to get it back to factory and tune her
Old 08-17-2008, 10:54 PM   #1724
It will be useless to have the factory settings as you are going to re-tune it anyway, so why don't you just fire it up and tune it from there, what fuel are you going to be using? what nitro percentage? I can at least let you know where to shim it at.
Old 08-17-2008, 11:02 PM   #1725
25%. Its already shimmed for that though
I need factory settings. Where it is at I know isnt right. Plus last time this sucker was ran, was last winter when it was nice and cold out.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
