Spektrum
Old 12-25-2006 | 01:37 AM
  #1981
Originally Posted by bmmer701
hehe it won't bind the led on the rx still flashing even if the led on the module stop flashing already...
you have to keep pushing the button on the transmitter for a while... if i remember well it was more than 20-30sec..
harris is offline
Old 12-25-2006 | 04:41 PM
  #1982
bmmer701's Avatar
I've tried holding the button and pressing the button for about 1 min or so but still didn't bind. It binded with my friend's module but mine didn't. i tried binding my two sr3000 to my module (not the pro) and it binded without any problem. Is there a possibility that my module won't bind any sr3500 micro rx?
bmmer701 is offline
Old 12-25-2006 | 11:53 PM
  #1983
Normally it works.. but it is better if you talk to them directly..
http://www.spektrumrc.com/About/Contact.aspx
harris is offline
Old 12-26-2006 | 07:11 AM
  #1984
bmmer701's Avatar
i was able to bind it already thanks for the help
bmmer701 is offline
Old 12-29-2006 | 05:44 PM
  #1985
pinggoy's Avatar
how you bind it?
pinggoy is offline
Old 12-29-2006 | 07:57 PM
  #1986
bmmer701's Avatar
Default re
Originally Posted by pinggoy
how you bind it?
i didn't notice that i plug the servo wires on the other side. (black wire should be in the outer part of the rx)
are you having problems binding your spektruM?
bmmer701 is offline
Old 12-29-2006 | 08:22 PM
  #1987
pinggoy's Avatar
never mind i got it..thanx
pinggoy is offline
Old 12-30-2006 | 08:24 AM
  #1988
jarkkom's Avatar
Bought a Spektrum Pro set for my M11 lately and having serious problems with it. It will shutdown, glitch, responding very slowly or not at all. First I thought it was the receiver so I swapped in the older receiver I knew was working. That didnt work and it was just like with the newer receiver. After that I changed the module on my M11 to the older one and it worked perfect. Also the older module worked just fine with the newer receiver. Does anyone know whats up with that thing? I did not have a cap since the og version worked fine without.. Oh yeah I have LRP Sphere Comp and Futaba 9451.
jarkkom is offline
Old 12-30-2006 | 09:57 AM
  #1989
JSJ Racing's Avatar
What batteries are you running? Make sure that the ESC is set to the correct battery mode.
JSJ Racing is offline
Old 12-30-2006 | 03:24 PM
  #1990
Tommy Bergfeldt's Avatar
Spektrum warranty service is nothing but top notch! I just got 2 pre-broke receivers back, one PRO who was just 2 weeks old when it started to glitch and a standard one with torn antenna.
Got the package back and found a paper i thought was a invoice since i bought the recievers in HK and hadn't got any receipts, i was so wrong.. They had replaced the PRO-series reciever free of charge with a brand new one and upgraded the old regular reciever with new software and new case. They even paid for the Express shipping back to Sweden.
Thanks to Spektrum!
Tommy Bergfeldt is offline
Old 01-01-2007 | 02:08 PM
  #1991
TL_XXX-S_racer's Avatar
Hey guys, I just got my Pro series and the micro receiver. After I bind the system and take the plug out, can I use that slot for a fan, or something else? or do I have to leave the slot empty. Cause I have my trans connected in the first slot then the esc and servo.
thanks,
Chris
TL_XXX-S_racer is offline
Old 01-01-2007 | 04:24 PM
  #1992
DirtyDog3375's Avatar
thanks,
Chris
As far as I know, the binding slot is only for that purpose only and cannot be used for any auxillary functions (ie. fans, power capacitor, etc.)
I'm sure GaryK from Spektrum will correct me if I am wrong.
Leonard.
DirtyDog3375 is offline
Old 01-02-2007 | 04:15 AM
  #1993
bmmer701's Avatar
Default re
thanks,
Chris
as far as i know you can use the plug for your fan... if you'll look at your bind plug it's like a "jumper" sort of thing...
bmmer701 is offline
Old 01-02-2007 | 06:23 AM
  #1994
Thanks guys, I have my fan soldered to the on and off switch and everything else, I just want to know if I can plug the fan into the slot. I want to do this cause it looks messy the way it is. lol
thanks
Chris
Old 01-02-2007 | 06:40 AM
  #1995
Capt.Micro's Avatar
thanks,
Chris
I have my fan plugged into the bind slot on my 3500 micro receiver and it works fine. the fan still comes on when the esc is turned on.
Capt.Micro is offline
