Tamiya mini thread
Old 07-19-2006 | 06:13 AM
  #226
H I's Avatar
H I
I just checked Tamiya Japan web site. Sorry TomB couldn't find any Hyundai accent you wanted so bad
But they got these :Tamiya mini just look at pic, unless you can read jap.
H I is offline
Old 07-19-2006 | 08:38 AM
  #227
itchy b's Avatar
Originally Posted by TomB
you figured out which model fits that mad datsun body joe?
unfotunately the 208 mm chassis must be the short wheelbase mini so the datto wont fit the mo3m
maybe i can get a short mini with bling wheels just to keep in the cabinet for display with the datto shell and of course some demo runs too
it sure looks fast just sitting there
itchy b is offline
Old 07-19-2006 | 02:13 PM
  #228
Tim K's Avatar
I ran my M03M with the Alfa body at Boronia last night.
To get the body to fit nicely you have to rotate the rear body posts 180 degrees to match up with the holes already drilled in the body. You also need to cut a 10mm square hole on the right hand side cowl grille area (where the bonnet meets the windscreen), this allows the body to clear the screw on top of the servo mounting plate and sit lower at the front.
Tim K is offline
Old 07-21-2006 | 10:06 AM
  #229
itchy b's Avatar
woohoo!
minis at ec whalan sunday!!
will we have 2 heats of minis or 15 car field???
bring it on
itchy b is offline
Old 07-21-2006 | 08:38 PM
  #230
PRospeked's Avatar
If the weather is ok tomorrow i will be out with my mini and my tourer, so you maybe add another mini or two to that list.
PRospeked is offline
Old 07-21-2006 | 09:16 PM
  #231
spewing. so the m chassis is what, 210mm? and the l must be maye 212mm?
bummer
TomB is offline
Old 07-21-2006 | 09:45 PM
  #232
itchy b's Avatar
bummer
the mo3m i believe is 225mm and the datto body is for the 208mm
chassis which is the rover mini cooper, but the suzuki swift looks good too and is more aerodynamic
itchy b is offline
Old 07-23-2006 | 01:28 AM
  #233
Corey The Great's Avatar
So how did the minis go today at Whalan
Corey The Great is offline
Old 07-23-2006 | 02:24 AM
  #234
danjoy25's Avatar
2 heats in Mini so its all good.
danjoy25 is offline
Old 07-23-2006 | 03:09 AM
  #235
Could someone tip me on what I need to get my mini competitive in relation to parts. I've brought the universals and the shocks could anybody give me the part numbers I need for the gearbox.
Looking specifically at running at Whalen
Old 07-23-2006 | 03:16 AM
  #236
danjoy25's Avatar
Here you go: http://www.tamiyausa.com/articles/fe...?article-id=12
danjoy25 is offline
Old 07-23-2006 | 03:19 AM
  #237
here is a list of stuff i found for the m03's and the m04m.
Differential
53267 - TA03 Ball Differential Set
53379 - Light Weight Diff. Balls
Parts:
53509 - HFC 0.6 Aluminium Pinion (20T)
53348 - M03 Ball Bearing Set
53390 - M03 Hollow Carbon Gear Shaft
53597 - M-Chassis Universal Shaft Set
53527 - 3x32mm Titanium Turnbuckles
53345 - M03 Toe-In Rear Upright
49198 - TRF Damper Set (Blue/4pcs.)
53488 - Adjustable Ball Connectors (*2 required for the mini)
TM3020 - tech racing aluminium king pin set
TM3060 - Tech racing alloy turnbuckle and tie rod set
53238 - Tamiya quick release battery holder
53333 - Touring Car tuned Spring Set (Short)
TL- 006V2BU - yeah racing blue alloy front upright (knuckles)
53389 - Tamiya mo4 aluminium heat sink
TA05 Tamiya 5mm blue alloy wheel hex adaptors
53341 - Tamiya mini cooper re-enforced rims
TA51236 -mini suzuki body
TA53068 - tamiya sports tuned motor
TA53204 – mini tyre inserts hard
TomB is offline
Old 07-23-2006 | 03:24 AM
  #238
So If I get these parts will this make me competitive
53267 TA03 Ball Differential Set
53379 Light Weight Diff. Balls
Old 07-23-2006 | 03:26 AM
  #239
Mad Mackem's Avatar
Did the Civic prevail?
Mad Mackem is offline
Old 07-23-2006 | 03:31 AM
  #240
danjoy25's Avatar
Got TQ. Won 1st Qualifier with a Civic and 2nd/3rd with a Swift but had to leave and couldn't run the final.
danjoy25 is offline
