Sirio engines thread
#1186
When I mounted the EVO 3 in my G4 I had to grind some material from the chassis because the bottom of the crankcase would otherwise touch the chassis, this would have caused a lot of stress on the crankcase.
#1187
Originally Posted by wyl03
no disputing that.
it was absolutely screaming down the straight @ moorebank.
having said that, i saw NR LS3, max S3 (?), LRP z12r doing the same too.
I think hes the only one ive ever seen racing with that engine.
#1188
NEED HELP
i have a sirio evo 3 , i use SH7 plug , 16% tornado fuel on a G4s gears : 19/24-51/46 , body blitz alfa romeo . surface temp 40C air 35-40 , the engine runs 120C with out the body and its too powerfull torg and speed , with body 150-160C and im loosing power torg and hi speed , by opening the main needle i loose more power , what should i do to have the same power and temp as with out the body
#1194
Originally Posted by shiston
Hi,
Anyone using these new Sirio STI engines?
I've been out of the racing seen for over a year now, try to crawl back in slowly
If they make me wait any longer, I might have to jump ship.
#1195
Hi,
#1196
Originally Posted by Corse-R
I have a pair of those 'Sti' puppies (the work on the innards are incredible), one ready to be mounted for break-in the weekend.
You lucky man
Would be cool to know how they go
#1198
A pair of them
You lucky man
You lucky man
You can see more about the milling I needed to do here. Needed to done it on the two and was really quick to do with a Dremel and the almighty carbide bit.
Don't know if is that crankcase (my previous Sirios, were the first black ones the S12TRP ABC) or mine engine mounts (Mugen), but people should take care regarding this and n-check if the crankcase touches the engine mounts by other place rather than the mounting holes.
Is the seed for infinity of problems (bad gear mesh, stripped gears, up to a broken crankcase or worse... a broken crankshaft).
#1199
They look really cool, but found some 'problems' with mine units when installing them on the motor blocks, the crankcase is too beefy (good!) and they were touching, needed to mill the engine mounts like this.
#1200
Originally Posted by Rody
I had the same problem with my Evo 3 going in the MTX4. I used Kawahara mounts and problem was solved!
1Likes
