T/E Maxx Thread
#316
Registered User
hey fire blade to you mean the new 2.5 motor or the .15 stock motor???? just asking... i just put a mugen .12 in a t maxx and fired it up last night and ran like a champ even running rich as heck... when it's broken in it will be a rocket compared to the new 2.5 motor since the power racting is .83 or .86 hp im not real sure i cant remember right now... compared to the .12 mugen rated at 1.15 hp and others can't duplicate the hp from this small .12 mill......
late teamatlas
late teamatlas
#319
Originally posted by fireblade
hold on now yall, it works of the impulses off the motor to draw more fuel off the carb
The "boost bottle/chamber" taps into the case below the carb and is supposed to give this backward pulse somewhere else to go besides out the carb throat. Then when the engine rev's up to higher rpm the increased intake vaccume is supposed to bleed that excess in the "bottle/chamber" back into the engine and be used.
Two inherent problems here. First the location of the pressure tap in most engine blocks is in the wrong place. Most all engines have the pressure tap drilled right below the carb inlet. Most carb throats are around 5.5 mm or so and the inlet of the pressure tap is about 1/8th inch. Pressure is going to seek least resistance so when the port in the crankshaft opens to the carb inlet the backpressure will still vent out the carb.
The pressure tap should actually be drilled in the block just below the carb inlet so the crank port opens to the pressure tap first, then open to the carb.
And then the second problem is most all boost bottles/chambers are not nearly large enough to be of any value. The bottle needs to be at least equal to or twice the volume of the entire crankcase volume.
Sorry, long post stating what all of us already know.
#321
You have to think outside the box here. Each intake stoke draws air and fuel into the bottom end of the engine. On the piston's down stroke pressure builds in the lower end of the engine which drives the fresh mixture up into the combustion chamber, but positive pressure in the bottom end of the engine also tries to push some of the fresh "FUEL/air" mixture back out then carb throat at low rev's because there is no vaccume created in the header from the tuned pipes reverse pulse to help draw the fresh charge into the combustion chamber.
Some of the excess mixture goes into the boost bottle. So you end up with air and fuel in the bottle. Since you can't see air you are only noticing the fuel in the bottle but there is air in there too.
Which btw, if you are finding much fuel in the bottle then you have it mounted wrong. It really should be mounted upright with the outlet pointing down and it should be above crank height.
(p.s. don't talk to "hobbyshop" guys.)
#323
Registered User
ok fireblade here is you exp on the boost bottle ... from a experet in the feild ok,,,,First, they are not in any way similar to Nitrous Oxide (NOS) systems on real cars, the hobby versions don't contain any Nitrous Oxide and they don't boost power.
R/C Boost bottles are designed to store a small amount of vacuum to stabilize the pressure inside the engine. Most people report little or no gain in performance. In many cases, you have to drill a hole in the crank case to connect them.
HPI does not make boost bottles for any engines
later dork .....
later dork .....
#324
later dork .....
later dork .....
Never said there was any NOS in them. But it would be cool though hehe
BTW- Whens the next time u are racing.
#328
Originally posted by TPhalen
not sure, but it will only handle 14.4volt motors...ie, stock, the trinity monster motors, or the reedy badmaxx motors. you will not be able to use any normal 05 size motor.
TPhalenSorry to burst your bubble but I have been using 05 motors in my E-Maxx for a while now and this thing really rocks!
I geared down and use P2K motors, no problems yet, even the ESC stays cool.
#330
Fireblade:
Nope the motors don't get that hot, I have been doing this for quite awile now with no ill effects so far.
My Maxx has alot of aluminum parts on it and it is still really fast just remember to keep a good eye on the comms because if the brushes get short the comm can be burnt.
