Tamiya TRF415
Originally Posted by Carl Giordano
415boy & axle..thanks for the response. I now understand the issue...with using the 415 front one-way and TA05 pulley....has anyone tried to used the front one-way for the TA05 on a 415MSX? Not sure if they are the same.
I will most likely use the Tamiya spool up front so I won't have this problem...your feedback helps if I decide to use the front one-way. Thanks
So now if I use the front spool, I need to get the TA05 locked center pulley. To get the proper 2.25 drive ratio which everyone is looking to achieve.
Or....I can just stick with the stock 415 stuff...although the white diff pulley's look trick
any full assembly from the TA05 wont fit in the 415 as the front belt in the 415 runs down the centre, and the 05 is offset. So thats why they are putting the 05 pulley on the 415 spools and one ways. I think thats what you were asking??? Shouldnt matter if your using the spool or the oneway on the 415, you can still use the TA05 one way pulley on the 415 parts. I just bought a set of 415 pulleys a few weekends ago, and Keith Yu then shows me his MSX at a recent race event and tells me how much better the TA05 pulleys are on the MSX.... doh!
Originally Posted by TRF415boy
You can either use the 415 or TA05 pulleys on the layshaft you'll have the same ratio.
Originally Posted by axle182
No problem Carl, Ill be hitting you up for answers when my MRX4 arrives
No problem with the MRX4 question...are your planning to travel to the GLC race this summer? If yes, feel free to stop by for some tips
thank you...I did not realize this??? So the 415 layshaft pulley (either fixed or dual one-ways) are the same # of teeth as the TA05?
YES
Originally Posted by Charles Godwin
Has anyone got a good tarmac rain set-up on pitshimizu narrow tyres , i think it is going to rain this weekend and i can't go on Saturday to test. Here is a link to the track
Charles
Charles
I just figured a dry setup with more droop and more ride height would be the go for a wet setup, but we don't race in the wet here in Australia, much to my disgust.
But from what i heard, the reason Marc etc are using the TA05, its lighter. that was probably mentioned earlier, but im too slack to re-read it all lol.
higuys out there...,.. im have my trf 415 for the 1st time.. im planning about to use it on tamiya super modified 11t... what is the recommended pinion and gear for that...? i want top acceleration and full speed. tnx...
I'll try that on Sunday then....if it rains
Cheers, Charles
Cheers, Charles
Originally Posted by Burlap
Ummm, with gearing it is either acceleration or top speed. Especially with different wound motors.
what shud be the gearings.?
ok how bout this... i want a good acceleration and a top a lil bit top speed....
