Tamiya TRF415
Hello,
The 415MS Stabilizers fits perfect (the same I think)
Originally Posted by Eirik
Hello Rick,
I have found the stiffer 3mm chassis to work better on carpet than the 2.5mm! The car is much more responsive and traction is about the same actually, but most important, the laptimes are faster with the 3mm
Also. the old suspension is easier to set up for carpet, it always work!!
I have been running the Accord body lately and I really like it, but if traction is low I would use the Stratus 3.0AP or the Mazda!
Good luck!!
Good luck!!
You might get the feeling of having more initial traction with the thinner chassis, but I feel that I have more steering and more corner speed with the 3mm chassis with the same rear traction!!
I also tested this with the old car and 3mm was much faster!!
Did you check out your laptimes when you tested?
I will do some more testing. Til now I have had the same laptimes with both chassis, this with the MSX.
Cool, let me know what you find out and I will do the same!!
Anybody that saw my post earlier about the steel outdrives I made for the Tamiya Spool, they work great I ran probably 25 packs through them with no problems.
Alan
Originally Posted by alan1467
Looks like a great mod do you have any better photos of where to cut the cups etc
Alan
Alan
Just wondering if you guys have any good ideas for mounting a personal traansponder in the MSX?
http://www.precisionrc.com/nv/car/pr...oduct_id=12551
The Square RC Servo/Personal transpmount is pretty awsome. Although i believe you have to shim the mount 4mm from the servo on the MSX like i have to on mine using the old regular transponder mount.
hi. i cant find my manual.
anyone knooe the part number for the front pulley? (just the black pulley, no outdrives required)
anyone know where to get the BLUE tape for the battery?
http://www.speedtechrc.com/store/ebp...nid=395&id=835
HiH
Ed
I ran my TRF415MSX last night with the gear ration 6.03. The track layout was tight and this time I feel that the car was faster. I think I am used to noisy shaft driven cars so when I switch to this car, I can't hear the noise so it feels slow. Actually, I am more consistant with this car than my EVO4.
